Rebuild necessary?
Old Mar 29, 2012 | 08:01 AM
Pssst's Avatar
Rebuild necessary?
Tried posting this in general and no luck...
I blew out a spark plug a few weeks back, and noticed my compression was low on a few cylinders and went to get it looked at and got the below results from the shop... I want to know what you guys would do in this scenario...
"Compression results
Cyl #1 95 PSI
Cyl #2 95 PSI
Cyl #3 75 PSI
Cyl #4 135 PSI
Leak down tested #3, found 20% sealing. Leakage could be heard in crankcase, the exhaust, and mostly in cylinder #2. Removed rockers from #3 and rotated and leakage into #2 still present. Rotated engine until #2 valves were closed and leakage into #2 ceased. Engine seems to have valve sealing issues in at least #3. Due to the overall condition of the engine, we recommend a complete teardown to ensure all issues are repaired"
My plan is to pull the motor myself, send it off to be built and put the motor back in myself. With the following parts...
Crankshaft: Manley (190100)
Connecting Rods: Manley H-Beam (14022-4)
Pistons: Wiseco .020" Over (K548M855)
Bearings: ACL Main & Rod + Thrust (5M1219H-STD & 4B1185H-STD & 1T1219)
Main Studs: ARP (207-5401)
Springs: GSC Power-Division 4G63T Single Beehive Spring set
Valves: MAP 4G63 High Performance Valves (DSM / Evo)
Studs: ARP Cylinder Head Studs (Evo) 207-4203
Head Gasket: OEM Mitsubishi (MLS) Evo 8
Timing Belt: OEM Mitsubishi
Opinions?
Old Mar 29, 2012 | 08:03 AM
okevolutionVIII's Avatar
Your parts list looks good....
Old Mar 29, 2012 | 08:09 AM
Pssst's Avatar
Thanks, am I right with the full rebuild or should I address something else with the issues listed?
Old Mar 29, 2012 | 09:06 AM
THUB's Avatar
You're definitely in the market for a rebuild. No question about it.
Old Mar 29, 2012 | 11:17 AM
Pssst's Avatar
Roger that, thank you! Just wanted to be sure I wasn't going overboard with the scenario
Old Mar 29, 2012 | 02:22 PM
Get everything done that you need to while the engine is apart. That's why my build took so long but I'm glad I did it.
Old Mar 29, 2012 | 04:21 PM
Pssst's Avatar
Yeah thats my thoughts exactly. Just ordered everything but the Manley crank Just want to make sure everything is done right when its apart Would hate to have to go in there twice
SEETO
Apr 25, 2017 12:59 PM
ISPEVO8
Feb 27, 2017 07:01 PM
11secEVO7
20
Jan 28, 2017 10:27 AM
polish_pounder
For Sale - Cars For Sale
Dec 1, 2016 07:38 PM
tscompusa
Oct 21, 2015 02:47 PM
