Off to Pruven & AL
Old Jan 21, 2004 | 11:08 AM
HobieKopek's Avatar
Originally posted by shiv@vishnu
FWIW, evo8power (aka Stiklr) is running a detuned baseline in his XEDE, not a custom tune or even a normal baseline map. Should be another 30whp left in it without haven't to get too aggressive.
shiv
Precisely why I asked. Thanks.
Old Jan 21, 2004 | 11:13 AM
Rollaway's Avatar
Stiklr... i guess i'll see you there... im on my way to Pruven right now
Old Jan 21, 2004 | 11:18 AM
Noize's Avatar
EvoM Administrator
shiv
I know. And he needs to sell me that XEDE for cheap so I can get an XEDEflash and tune it on a dyno!!
Hear me Stikilr?!? You are getting sleeeeeeeeeeeeepy. You want to hook Noize up with one heck of a deeeeeeeeeal on that XEDE.
Old Jan 21, 2004 | 11:56 AM
nonmature's Avatar
I will pay .01 thats one whole penny over what Noize will pay for the XEDE.... ha take that NOIZE....
-non
Old Jan 21, 2004 | 11:58 AM
Noize's Avatar
EvoM Administrator
DUDE!! Don't be screwing up my first attempt at over the internet hypnosis. That XEDE is mine, bish!!!
Old Jan 21, 2004 | 12:00 PM
Ferb's Avatar
FWIW, evo8power (aka Stiklr) is running a detuned baseline in his XEDE, not a custom tune or even a normal baseline map. Should be another 30whp left in it without having to get too aggressive.
shiv
Was there a reason it's a detuned baseline?
ferb!
Old Jan 21, 2004 | 12:12 PM
shiv@vishnu's Avatar
ferb!
It was a last ditch effort to help him from hitting the boost cut. Turned out later that his aftermarket BOV was leaking so I guess we were barking up the wrong tree. Also detuned it a bit to play it safe with the aftermarket intake he had.
my 2c,
shiv
Old Jan 21, 2004 | 12:16 PM
Eric Lyublinsky's Avatar
ferb!
Ferb
Under EVO8's handle you will see a list of mods. One of them being an intake from RMR. All intakes change the MAF reading over stock so in will run lean under some load points. I'm sure it's a richer map to compensate for those leaner load points with the intake.
Not being able to see what the car is doing on a dyno and have the ture A/F reading, better play it safe then sorry and detune the map for motor life. Custom tuning would yeld a smoother runing car with at least a 30hp gain.
I have a XEDE and Cat back and was custom tuned by Shiv from Vishnu on the same dyno that this guy is going to.
Here is the dyno graph so that you can see the diffrence between base map and custom tuning.
all on 93oct I make 231whp bone stock.
The trick is realy simple when it come to mail order maps. Follow the suggested upgrade path by the tuner of ideal results.
Eric
Old Jan 21, 2004 | 12:36 PM
Fourdoor's Avatar
Originally posted by Eric Lyublinsky
Ferb
Eric
Good information! I would love to see three things. Stikilr's base line compared to the results from a "mail in" reflash. Then Stikilrs "mail in" reflash compared to Eric's baseline run, and then finally Stikilr's dyno tuned map as compared to Eric's dyno tuned map.
Keith
Old Jan 21, 2004 | 12:46 PM
Keith
Keith I would to.
But there are allot of things to consider when comparing. I was tuned in September about 65f today it's closer to 0f. Also I only had a XEDE and cat back exhaust. This guy is running more mods. So he should at least gain 15whp more then me with proper tuning even at the same A/F because his turbo effencey would yield higher results.
Eric
Old Jan 21, 2004 | 01:26 PM
Chris in HB's Avatar
Just a note on the intake: the suction pipe (intake pipe, whatever you want to call it - it replaces that accordion-looking unit) REALLY leans out the Evo's A/Fs... My car had a great flash done prior to putting that pipe on. After that pipe, my A/Fs jumped to 14.3s! OUCH. Al brought them back down to 11.1 and advanced the timing. I am heading up to Pruven soon to get dyno'ed and have Al do some fine-tuning then. I am glad this thread is staying civil. It's good to talk shop without worrying about nonsense.
Old Jan 21, 2004 | 01:30 PM
Really? Great info Chris I was wondering my self. I like the ralliart one!
Old Jan 21, 2004 | 01:38 PM
I have the RMR pipe but it's pretty much the same as the Cusco and Ralliart except for the color. Al said he's seen them really lean out the A/Fs to dangerous points - much like mine. I think I will still go a little leaner than 11.1 - more toward 11.8s...
Old Jan 21, 2004 | 01:41 PM
Stikilr's Avatar
In Timeout
Shivs getting scared that me and Al are gonna smoke his HP readings on the EXEDE, im downloading my original MAP before i go to Pruven WED so i will be running a basic 93 octane MAP, so at best i would have 300...at best with a HIGHLY TUNNED EXEDE, so we will see, and I already sold my EXEDE..sorry.....Cant wait to see ya Al!!!!!
Old Jan 21, 2004 | 01:50 PM
HobieKopek's Avatar
And the hook has been baited. Again, another friendly reminder to please keep the thread civil and avoid bashing and name calling.
To compare products is wonderful. Pros and cons are great. Use your best judgement.
