Replacing one piston?
Old Apr 1, 2012 | 08:01 AM
FL_SilverEvo8's Avatar
One of my pistons is chipped. Should I be ok replacing this one or should I replace them all? I am going to re-ring all the pistons. I did look at the cyclender walls of the one chipped one and it is fine. I just want to know if I can get away with just re placing that one.
On a norther note( this is weird) I did a leak down test to my car and it seems that cyclender 1 and 4 are fine but when I did 2 and 3 I have probs. Bent intake valve in cyclender 2 and messed up rings in cyclender 3. But yet the cyclender walls in 3 are fine. And there is no chip on the piston in cyclender 2. Is it posable that cyclender 3 rings could of cupped? Some told me it could do that and not do any damage to the cyclender walls.
Thanks for looking at my post and the help people. That's why I always on this site. Awesome feed back and great people.
Old Apr 1, 2012 | 06:29 PM
flyingscot's Avatar
im judging by the lack of answers that most folks are face palming
why indeed would you open her up and replace only one piston,think about that!
doesnt make a lot of sense does it,anyway this could well be an april fools and im the fool
Old Apr 2, 2012 | 08:37 AM
newbieEVO8's Avatar
I'm faced with the same issue right now.
Old Apr 2, 2012 | 08:45 AM
BoostINurI's Avatar
Just do it right guys....please for the cars sake lol.
I know its a pita to do but its better than doing it twice if not three times.
Old Apr 2, 2012 | 09:38 AM
newbieEVO8's Avatar
I think I am going to do a set of drop in rods and pistons. I am getting a stage III head from Buschur.
Old Apr 2, 2012 | 11:33 AM
korizmo's Avatar
I chipped one piston and said F it and built the whole damn thing. Manley pistons and rods. The stock internals are junk. Pull the motor, build it or drop it off at a machine shop. Couldn't be happier.
Old Apr 2, 2012 | 11:39 AM
EvoDom's Avatar
ive seen people change one piston before and never had any problems. But in your case your have alot more things wrong then one piston needing to be changed. Build the car right.
send the head out to be done, and buy new bearings, pistons and rods when you have the funds. The car will cost you alot more in the long run if you just "slap" it back together....
Dom
Old Apr 2, 2012 | 12:35 PM
akauf's Avatar
this is your lr2.4?
assuming you dont have a ton of miles on the motor:
Get two pistons, get the weight right so you have a balanced set, re-ring all 4 and put in some rod bearings while your at it.
clean everything out really well.,, inspect your turbine wheel, yada yada, be thorough.
Old Apr 4, 2012 | 05:37 AM
Yes it is my 2.4. With very low miles on it. I don't even think I have 5k miles on it. I am going to rebuild the head for sure. I already have valve springs and retainers in it I need to get some good valves. The pistons are good other than one. Yes I am going to re-ring them and clean the pistons. Also put new rod bearings. Do I or should I do the crank bearings also? I did call up Manley and they said I could buy just one piston. Why would I need to my 2 ?
Old Apr 4, 2012 | 06:55 AM
94AWDcoupe's Avatar
do you have pictures of chipped piston?
most cases the bore gets damaged. in which case dropping in another piston is a bad idea
Old Apr 4, 2012 | 07:06 AM
newbieEVO8's Avatar
I would measure the bore just to be extra safe that you are getting the right sized piston and rings.
[offtopic] when you purchase a piston and ring set, are the rings that come with the pistons sized correctly or would you have a machine shop double check and file them to size if needed?[/offtopic]
Old Apr 4, 2012 | 08:13 AM
tscompusa's Avatar
if you replace the rings the block atleast should get a mild touch hone..
any idea how the piston cracked?
Old Apr 4, 2012 | 08:19 AM
newbieEVO8's Avatar
If that is in response to my question, yes I will give the cylinder walls a mild honing.
Old Apr 4, 2012 | 08:29 AM
tscompusa's Avatar
it was for the OP.. for you though.. depends on piston brand. some manufacturers gap rings ok already and dont need shaved (manley).. either way you need to check regardless to know what is going on.. doesn't take more then 30 seconds with a feeler gauge.. i would adjust the gap based on your power level and usage for the engine.
Evo47
Mar 20, 2017 12:00 PM
tscompusa
158
Jan 17, 2017 02:52 PM
tscompusa
May 5, 2015 08:30 PM
9GUY9
327
Dec 17, 2013 09:16 PM
Fishd0
34
Apr 11, 2013 12:48 PM
