How can i connect AEM W/B onto a laptop?
Old Apr 14, 2012 | 03:45 AM
jameswwt's Avatar
Hi,
do anyone know on how to connect/link Universal AEM Wideband 02 Gauge and Sensor (Full Kit) UEGO - 30-4100 onto Evoscan via laptop?
Thanks
Old Apr 14, 2012 | 06:59 AM
Sirnixalot's Avatar
Have you read the manual? Specifically page 6?
http://www.aemelectronics.com/Images...%2030-4100.pdf
Also unless your laptop is old you will need a USB to serial adapter
Old Apr 14, 2012 | 08:41 AM
jameswwt's Avatar
Oic...Thanks
but can i just splice pin 75 from the ecu and directly connect onto the splice white analog wideband wire?
Old Apr 14, 2012 | 10:38 PM
jameswwt's Avatar
Anyone?
Old Apr 14, 2012 | 10:41 PM
Drifting Away's Avatar
There is a thread about this ( or several) in the ECU flash section. But yes you can.
Old Apr 14, 2012 | 11:35 PM
jameswwt's Avatar
Thanks and i just needing the way on how to link my AEM WB onto my Evoscan via laptop so that i can start proceed for my ecuflash tune.
Old Apr 15, 2012 | 01:27 AM
AWDBus's Avatar
https://www.evolutionm.net/forums/la...o-evoscan.html
Not trying to be a dick, but this was two clicks in the EcuFlash forum.
Old Apr 15, 2012 | 03:52 AM
jameswwt's Avatar
Hi AWD, thanks
Old Apr 15, 2012 | 01:50 PM
AWDBus's Avatar
No problem man, I did it in my car and works great. I think I had to change the scaling a bit tho to match up to mine.
Old Apr 21, 2012 | 07:16 AM
jameswwt's Avatar
Hi AWDBus,
ive switch to another way of linking my aem eugo wb to evoscan.
Ive tried numerous ways of linking it but my evoscan just wont link with the external wideband!
Its seems as simple as ABC but in fact has caused me 2 nites of nightmares!
1st, i link the aem eugo 4pin blue wire to the serial output pin 2 and grounded the output pin 5 to my car metal body.
2nd, ive selected the wideband selection from evoscan aem 9600.
3rd, select COM's from 1~9 but yet all the above still cant get me link my aem wb to my evoscan.
Any other idea for me to link my wb to evoscan? Can i follow you way but my evo 6 ecu pin 75 is not a Lamdba Rear.
Pls help...
Thanks
LAN_EVO
Mar 23, 2013 07:55 AM
jameswwt
Apr 22, 2012 09:20 AM
3gEclipseTurbo
AEM EMS
13
Apr 22, 2012 08:17 AM
brenner
Jan 27, 2010 12:25 PM
2.3 Evo 8
AEM EMS
Sep 28, 2009 06:14 AM
