1st gen fp green
Old Apr 24, 2012 | 11:53 PM
letoevo8's Avatar
1st gen fp green
hey all i have been searching all over the net for the flow rate of the first gen fp green and if this turbo will be a improvement over the standard evo 9 turbo.
thx adam
Old Apr 25, 2012 | 12:07 AM
SOEuro's Avatar
old school green was 49 lbs per min
IX turbo is 44-45 lbs per min, I think...not 100% sure
Old Apr 25, 2012 | 04:29 AM
letoevo8's Avatar
ok thx it should be a slight improvement then over the evo 9 turbo with a fast spool great for the street
Old Dec 7, 2013 | 10:59 AM
NUR's Avatar
NUR
Hey guys had a question on the 1st gen fp green so thought of posting it here than making a new thread, I recently purchased a 2nd hand 1st gen fp green turbo (JB), the turbine had a very slight shaft play, should this be a major problem? I am new to this and kinda worried.
Old Dec 7, 2013 | 11:19 AM
ctfpevoVIII's Avatar
thx adam
I use to have one it's 49 lb/min, it will offer a small bump in power over the 9 turbo.
Old Dec 7, 2013 | 11:20 AM
As long as its slight side to side and not in and out you should be fine.
Old Dec 7, 2013 | 11:56 AM
NUR's Avatar
NUR
Thanks, it was side to side but very little.
Old Dec 7, 2013 | 09:52 PM
Thore's Avatar
Hope this helps.
http://www.ziptiedynowerks.com/tech/turbo-flow-rates/
I've been looking at upgrading my 1g FP Green. From what i've heard, the general consensus is the old school green is a little better than an Evo IX turbo but not by much (that would justify swapping out a IX turbo for one.) On pump gas (92 here) they tend to top out at around 400 give or take 20hp. Of course you can get higher on E85.
As for the other question.
From Forced Performance's FAQ:
Q. The shaft in my turbo feels loose. How much freeplay should I have?
A. While this specification does vary from one brand to another and rule of thumb is less than .030" radial freeplay and less that .002" axial freeplay.
This amount of freeplay is required to allow the bearings to "float" in a pressurized film of oil while the engine is running. The flow of oil through the clearance around the bearings is what helps the bearings stay cool. This oil film around the bearings also help dampen vibrations that occur to the rotating assembly as it moves through it range of RPM. Ball bearing turbochargers do not have this pressurized film of oil around the bearings; this is why they are somewhat more noisy than floating journal bearing turbos.
pls1968
Jul 13, 2020 01:16 PM
PHILLY EVO
Sep 9, 2016 04:16 PM
illogicalmind
Mar 24, 2016 03:30 PM
IRISHEVOX
12
Jan 9, 2014 04:15 PM
Mevo8M
14
Dec 2, 2012 12:29 AM
