SWEET! Another blown motor maybe? HELP! *MANY PICS!* Start analyzing
I am definitely sending out the injectors at this point. I really hope I find there is a bad one or two. It will really put my mind at ease as to why I've had so many problems with the motor.
I am very frustrated at this point. I have put a lot of hard-earned money into the car, used the best parts, cut no corners, and a lot of wrenching. I just hope the injectors come up as being bad. At this point, I have to spend more money and I can't do anything about that - just would like to know that swapping the injectors and getting retuned fixes the problem and don't have to worry so much.
I know given the car is modified I can't expect the car to be 100% reliable, but I don't think I should have problems this regularly. Do most of you guys over 400whp have relatively reliable Evos?
Im not to familar with the 2.1 shortblocks but i can tell you this. I snapped my kelford intake cam a while back and bent all 16 valves. The cam snapped because the ****ty BRO tune i had in the car. Motor went into a complete melt down and one of the pistons actually locked up in the cylinder and all that torque just sheered the cam in half. Anyways blowing coolant every where and popping freeze plugs means the head a lifting under boost from detonation. Call Raif, let him take a look at the car and get it straightened out for you.
Hi David and thanks for your reply. The car has been completely retuned since it was put back together with the new motor. i went to one of the most reputable tuners in my area, and I know he wiped out the old tune and started from scratch. I am just very confused about my car... I went to one of the best guys out here for my tune. :/
Car is strictly 93 oct only. I did re-use the L19's as they only had a couple hundred miles on them. I made sure everything was torqued 100% when assembling the motor.
I did not modify the MIVEC cam for the taller deck height - please elaborate on this since I don't know what I would modify. Car is running 27psi and IDC gets upward of 90-95% under high boost. AFR's are about 12.5 under initial spool and quickly drop to 10.8-11.2 as boost comes on.
I actually did log the car the other day and was getting some odd knock count and could feel it (probably was one of the plugs going or gone). I replaced some IC clamps and resolved a boost leak, and knock went away and car was running great.
Also, just did my compression test. Looks like the head has to come off
178-100-178-152
178-100-178-152
That really sucks man. Thats a lot of repeated carnage on your car. Let us know if there is anything we can do to help if you need it. I'm curious to see how balanced the injectors are too.
-Jamie
-Jamie
Dude sorry to tell you "the shop" is garbage! I would nottt be surprise like david buschur said and others if the tune keeps ***kin ur car up. I had first hand experience with them and will never recommend them to anybody to go to again bunch of thieves. Also have have a few friends that blew there motors after getting tuned/ built my them. I would def look elsewhere for a tune though they are far from " the best" in the tristate area many other reputable people out there
.Anyways goodluck man i hope you get it resolved. I would not be very much surprised if this is 95% your problem
My apologies David. I was in no way trying to undermine your knowledge. I am just very frustrated with the car right now. The money I have put into it hasn't been a walk in the park for me.
The head wasn't sealing properly and the headgasket leaking was pressurizing the cooling system with exhaust. Way too much pressure for cooling system.
Ignition timing from a garbage tune is likely burning through the hgasket and or lifting the head. Your valve springs sound like they are too stiff and have broken the cam. Let me guess, dual springs on a street car? How are you claiming to retard a STOCK camgear? They are NON ADJUSTIBLE!
