Rebuilt my ACD Pump
Old Apr 12, 2016 | 10:19 AM
  #61
firmk20's Avatar
another good read but I'm curious to when it would be a good idea to rebuild a pump or clean aside from it not working.
Old Jul 11, 2016 | 05:21 PM
  #62
Teal2nnr's Avatar
Bump. Anyone know where to get parts?
Old Jul 12, 2016 | 05:35 AM
  #63
Erraticevo666's Avatar
You can order rebuild kits on Ebay.
Old Jul 12, 2016 | 07:38 AM
  #64
heel2toe's Avatar
Teal- I have a brand new kit I'll sell to you if you're interested...PM me if you'd like. Alternatively you can find rebuild kits online i.e ebay
Old Jul 22, 2016 | 04:56 PM
  #65
CeliOnce's Avatar
So in my efforts to take my pump apart, I'm a little worried I've screwed myself. In (attempting) to take the body apart, one screw came out pretty easily but the other wouldn't budge stripped, so I figured I'd try to drill the head out. It's not example going well as I have no machining skills, see the pictures:
https://s31.postimg.org/5wxrp05yj/IMG_0124.jpg
https://s31.postimg.org/p3ays6mgb/IMG_0125.jpg
It's eating up drill bits quicker than than the bolt itself.
Any suggestions where to go from here?
Old Jul 23, 2016 | 03:48 AM
  #66
kikiturbo's Avatar
looks like you managed to drill out the head.. now you will need to bang it about with a wooden hammer...
usually the both parts of the body are stuck due to corrosion so need some hammering..
Old Jul 23, 2016 | 08:18 AM
  #67
CeliOnce's Avatar
So I've pried into bolt shaft area between the two body pieces and I can get the body wiggling so I know it's loose but that bolt, and whatever I've done to it, is still holding it on.
Any ideas what I can do to get the bolt head off? Keep drilling?
Old Jul 23, 2016 | 05:43 PM
  #68
CeliOnce's Avatar
Got it. Drilled a little more and died some prying and then it cracked off. Got a vice grip on the bolt shaft and it came out no problem. Bonus: the plate that gets replaced came half off with the body. Only tricky part left is getting the bearing out.
Old Jul 24, 2016 | 02:12 AM
  #69
kikiturbo's Avatar
usually you can just hit the bearing out with a hammer...
Old Jul 26, 2016 | 10:39 AM
  #70
Mr9S's Avatar
Any updates on your project Celione? Following this thread closely as I am also doing mine. But a friend jet washed my AYC pump. Now I need to wait for it to completely dry before starting. Hmmphhh
Old Jul 26, 2016 | 02:55 PM
  #71
CeliOnce's Avatar
The pump is back together and tested to run. I'll be installing this weekend and seeing how it goes.
Old Jul 27, 2016 | 03:32 PM
  #72
CeliOnce's Avatar
Installed the pump. I can run and bleed it manually but still 3 lights - must be an electrical problem as I can't get the pump to run by holding down the accelerator and turn the ignition on.
Old Jul 28, 2016 | 12:42 AM
  #73
kikiturbo's Avatar
is the 3 lights on right away or does it light up after a while ?
Old Aug 2, 2016 | 10:08 AM
  #74
Mr9S's Avatar
Light up right away means electrical (loose / wrong connection, etc) and if it lights up after a while, it means problems with the pump. Correct?
Btw, i got to that point of drilling the the heads off the two bolts between the two body pieces. Its a PITA to get it off. Will continue over the weekend.
Old Aug 2, 2016 | 10:28 AM
  #75
kikiturbo's Avatar
yes.. light right away means either a broken pressure sensor or problem in the loom
due to pump position and orientation on us cars you always have motor bearing problems and corroded inside bolts.. taking the pump apart is always a pita
