maf to sd conversion
im just trying to get everything in order. i want to convert my 9 to sd. i searched and found nothing on the actual parts and things needed to be done. all i found were threads that supposedly had that info but was a ton of brewhaha about how sd works and how much better it is. i would like the actual procedure to do the swap
Plug your intake, get a MAP sensor and a tune. Your tuner will most likely use your fuel temp sensor, so don't worry about getting an IAT.
You'll need a different map sensor like an Omni 4 bar, and an intake setup for SD if you want. You can also go to a VTA bov or just vent your current one. Then get a tune. Biggest thing is getting an aftermarket map sensor and the tune.
hmmmmmm, interesting. well the plan was to install all the parts im planning and tow it to the tuner.
is using that gas tank temp sensor safe to use as a iat? i just want to be sure, dont want **** going crazy
Jonathan Brito
Aug 5, 2016 02:16 AM
WTB[MidWest]: SD Intake w/ Recirc
evopwned
Mar 7, 2016 04:55 AM
