Half radiator mounting issue
Old May 6, 2012 | 04:01 PM
Svendiesel's Avatar
Ive got a half Koyorad and the driver side OEM mount obviously works perfectly fine. My plan was to drill a hole right behind the hood latch to mount the "passenger" side rad mount with a bolt and nut. Problem is, my hood wont close.
Ive seen pictures of a few engine bays with the OEM rad mounts set up in the exact way I wanted to mount mine. How does your hood close?! Mine wont close because it seems like the hump on the hood where the latch latches is hitting the radiator mount since it sticks up quite a bit.
Do you need to trim that part of the hood? Dremel down the rad mount a bit? Halppppp.
Old May 6, 2012 | 04:25 PM
stinkbomb's Avatar
post a pic
Old May 6, 2012 | 04:30 PM
wizzo 8's Avatar
I'm assuming you will have to trim the hood. Subscribed for other input
Old May 8, 2012 | 09:11 PM
Svendiesel's Avatar
Heres an example of it working perfectly fine
Heres my halfassed rigging right now just to keep it from bouncing around, I have it ziptied thru the hole I drilled to bolt the bracket down and a shot of the hood where I believe the bracket is hitting
Old May 15, 2012 | 10:48 PM
Svendiesel's Avatar
Bump anyoneeeeeeee
Old May 21, 2012 | 01:55 AM
evo7_8u's Avatar
i also would like to know , i thought about buying the slim torque solutions radiator brackets and see if that solves the problem ..
Old May 30, 2012 | 03:35 PM
Svendiesel's Avatar
halpppp
DSSA
Evo X How Tos / Installations
19
Sep 7, 2017 02:57 AM
rong.
Jun 20, 2016 06:23 AM
Victor Kasper
Nov 7, 2015 12:08 AM
Boostin_AWD
May 25, 2012 01:59 PM
silex
Mar 16, 2007 06:32 PM
