hesistating at WOT
Old May 7, 2012 | 12:30 AM
stunt2's Avatar
Arrow hesistating at WOT
so, car bucks and hesistates at wot, as soon as it begins building boost. if I pull at part throttle things go more or less smooth, but as soon as I go WOT, it kinda misfires, bangs from exhaust and won't accelerate.
changed spark plugs to used but known good ones, also switched to COP setup and it helped a lot, but still does same thing at 14-16 psi
spark blowout/gap ? bad MAF ? boost leak ? tune? fuel starvation ? (have hardwired walbro).
which way to look for problem
Old May 7, 2012 | 12:24 PM
marcusE's Avatar
change plugs and gap at .022
Old May 7, 2012 | 02:49 PM
cazlow's Avatar
Ya... get new plugs first for sure and go from there.
Old May 7, 2012 | 03:28 PM
420a-t's Avatar
do you have a wideband?
Old May 7, 2012 | 04:38 PM
srtboostin22's Avatar
ive been having the same problem with my car ever since it got cold out.. made 740ish on my 3586 in the summer.. ran great.. got cold out and breaks up HORRIBLE.. only on warm days it runs great..
Old May 7, 2012 | 04:43 PM
marcusE's Avatar
lyke omg change sparks plugs
Old May 7, 2012 | 11:45 PM
stunt2's Avatar
I do have wideband but haven't managed to hook it up yet, so no idea about afrs
will try and change plugs first
Old May 8, 2012 | 12:14 AM
SANDIEGOSFINEST's Avatar
when did you install the wally? have you checked your fuel pressure?
Old May 8, 2012 | 01:54 AM
stunt2's Avatar
was on the car when bought + hardwired and no, I haven't checked the fuel pressure
can it be a fault for the symptoms above ?
Old May 14, 2012 | 04:45 PM
Levar's Avatar
Veteran: Army
What fuel are you using, my friend?
otter
36
May 15, 2015 06:57 PM
LakerRaider
30
Aug 7, 2014 12:54 PM
BulletProof
14
Mar 24, 2013 01:41 AM
DamoCN9AIV
Jun 6, 2012 07:43 AM
whiptheevo8
Nov 11, 2009 09:05 AM
