choosing IC
Old May 14, 2012 | 01:38 AM
4ukc's Avatar
choosing IC
need advice plz
ATM I have 3.5" Perrin with in/outlet 2.5", and I am going to install 3" TB so I would like to make piping 3" and IC with outlet 3", I came across on
http://www.maperformance.com/treadst...hick-3138.html
what do you think? or may be there is smth better? or its is better to stay with perrin?
Old May 14, 2012 | 07:27 AM
Thore's Avatar
Link no workie...
Old May 14, 2012 | 11:16 AM
4ukc's Avatar
Old May 14, 2012 | 11:48 AM
gsrboi80's Avatar
The issues you will run into is that looking at that IC the inlet/outlet of the IC come straight out so you may see once mocked up that some bumper modification may be needed
Old May 14, 2012 | 11:55 AM
4ukc's Avatar
I do realise it, but I am wondering is it as good as Perrin?
I am going to install a 3" TB and I would like to make piping 3".
I undertand about lag with bigger piping, but in case I will lower the incoming air temp I will be able to make more agressive angles - result is more POWER, and thats what I need
Old May 14, 2012 | 01:10 PM
4ukc's Avatar
I have just checked sizing
perrin - 25" x 11.75" x 3.5"
tread - 22" X 12,5" X 3.5/4.5 I am looking to get 4.5"
Old May 14, 2012 | 06:22 PM
Adam Brunson's Avatar
Like I recommended in my PM to you, I would recommend sticking with what you have before jumping up to a 3" UICP, as it is overkill for your turbo/setup.
Old May 14, 2012 | 07:09 PM
domestickillaAR's Avatar
agree unless you have a setup to support and Need 3inch IC pipes you will gain nothing by doing so. its been tested time n time again.. actually i think david buschur did the tests years!!!! ago. 2.5inch IC pipes and maybe a 4inch high flow core n you should be good for 800whp
Old May 15, 2012 | 10:41 AM
4ukc's Avatar
ok, will get 6466 or 6766 first )))
thanks
Old May 15, 2012 | 11:08 AM
6466!!!
Old May 15, 2012 | 11:12 AM
Kracka's Avatar
The Perrin intercooler core is actually 3.625" and is a very effective and proven unit; keep it.
Old May 15, 2012 | 12:00 PM
Brent_si's Avatar
The perrin is good only one I liked more is the buschur race. I would keep it as well.
Old May 15, 2012 | 01:28 PM
evo8in203's Avatar
buschur is good, and perrin
Old May 15, 2012 | 01:53 PM
4ukc's Avatar
thanks for your help! first turbo, second buschur IC
Old May 15, 2012 | 04:38 PM
I would go with turbo, then when it comes time to make some power, do an ETS intercooler.
