Speedometer stopped working, no check engine light
Old May 20, 2012 | 12:03 PM
EVO TYME!'s Avatar
Well i just finshed a clutch install friday. Saturday morning we drove out to a car, it was about 140 miles tound trip . Flawless everything was working fine. After i got home and left again my speedometer and tripometer werent working. Also my service engine light was on but the car was driving fine. I checked the vss plug and its still plugged in. There is no cel's. Coukd my vss have went bad randomly and not thrown a cel? Any ideas?
Car is a 2003
Old May 20, 2012 | 01:16 PM
KentStateTsi's Avatar
Veteran: Army
Having a similar problem as well. As long as I am pushing the gas pedal the speedo works fine. As soon as I let off it drops to 0.
Old May 20, 2012 | 08:58 PM
mithrandir7533's Avatar
If you just had a Clutch job completed, I would check and make sure the speedo gear located in the top of the tranny towards the back hasn't been damaged. Is your RPM gauge still working?
Old May 20, 2012 | 09:04 PM
RoMeIX's Avatar
This is what I was just coming here to post, I would bet that it is somehow related to the clutch work you just did
Old May 21, 2012 | 06:22 AM
EVO TYME!'s Avatar
Yeah the rpm gauge is still working. I'm going to pull the vss out when i get home from work and see if somehow it got damaged. Just seems weird it was fine for 130+ miles after the install..
Old May 21, 2012 | 06:29 AM
boostzealot's Avatar
Im hoping that somehow that tranny doesnt have the same vss as an MR does. The reason i say that is because the MR's have a hall effect type vss instead of a gear driven vss like the 5spd cars do. If your vss isnt working it may be because either the vss plug came undone, or the tranny harness plug wasnt fully seated after the clutch install. Also please verify that the vss itself is fully bolted down and it may be a pain in the *** but put that little metal clip back in the vss plug if its not there.
bruce988jl
May 19, 2017 02:58 PM
BlackEvoV
Lancer Troubleshooting
Dec 8, 2015 06:26 AM
Brad676
Aug 13, 2014 10:10 PM
silverevo05
Jun 19, 2011 12:34 PM
rgar
Aug 9, 2010 05:49 PM
