Which Injector Brand???
Old Jun 3, 2012 | 08:55 AM
jameswwt's Avatar
Hi Guys,
im currently using sard 850cc injector and im planing to change to other brand as im having problem to get the scaling & latencies correct.
My current scaling is = 943 cc/min
Latencies = 6.120 / 3.120 / 1.992 / 1.320 / 1.008 / 0.672 / 0.408
Have been cracking our head on figuring out the scaling and the 943cc/min got the nearest AFR of 14.7
Pls kindly advise which injector brand suit Evo's most as i know some injector doesn't close up quick enough resulting on rich AFR during Throttle Lift Off?
1) FIC
2) Precision - PTE
3) Power Enterprise - PE
4) RC
5) Denso
Which brand will come with their precise Scaling & Latencies Table/Details?
Thanks
Old Jun 3, 2012 | 09:00 AM
foxbear2277's Avatar
I will be running ID but its not on your list... Out of the ones listed, every company I contacted about my build advised me and point me in the direction of FIC (Seccond to ID, companies pretty much told me if I want to save some money, go FIC over ID)
Old Jun 3, 2012 | 09:15 AM
EVOn9ne's Avatar
Injector dynamics hands down
Old Jun 3, 2012 | 09:16 AM
jameswwt's Avatar
Thanks FoxBear
Old Jun 3, 2012 | 09:17 AM
wjamyers's Avatar
after my research for my needs (93octane) I decided FIC 1100 were a solid choice. work just like stock, only down side is they're loud enough to hear but that's only when you're standing over the engine so who cares?
Old Jun 3, 2012 | 09:19 AM
jameswwt's Avatar
Thanks EVOn9ne
Old Jun 3, 2012 | 09:20 AM
jameswwt's Avatar
Thanks Man...
Old Jun 3, 2012 | 10:47 AM
jspecteggy's Avatar
ID then FIC, like the one above said ID's are a bit more expensive. This link should help you some http://www.injectordynamics.com/ID10...d Time Summary Flow Rate and Dead Time Summary
Old Jun 3, 2012 | 11:26 AM
Mellon Racing's Avatar
we've been having good luck with FIC for years now
Old Jun 3, 2012 | 11:49 AM
Supergoslow's Avatar
FIC's are your best bet for price and streetability. I had 1100's and they ran great on pump
Old Jun 3, 2012 | 12:47 PM
boozeup&riot's Avatar
Many of the injectors on your list are all running the same core: the Bosch EV 14.
There are other entities offering these injectors too. One is a vendor here, Race Comp Engineering. The owner, Frank sold me a set for a fraction of the cost of ID's or FIC. before going in to my car this week, they'll be flow benched out here and tested to see how they behave. Another group, Fuel Injector Connection offered me a deal on the same set (Bosch EV 14) with plug and play adapters for a little over $300.00 shipped.
I'm not slamming any of these other vendors. Many people have great things to say about FIC and ID. I encourage you to look into the warm start issues affecting some of the people running ID. FIC seems to have treated many people as good, or better than the ID. Shop around, do some searching, you may find the injectors you want for much much less. Either way, no one has given you bad advice.
Old Jun 3, 2012 | 01:16 PM
spoilboy1's Avatar
Go with the Injector dynamics.
Old Jun 3, 2012 | 06:02 PM
jameswwt's Avatar
Thank you so much Guys...
Old Jun 3, 2012 | 06:13 PM
jameswwt's Avatar
Btw, by using s larger injector will it consume more fuel? Some say their car consume lesser fuel with a smaller cc injector compare to bigger injector with same power band.
Old Jun 3, 2012 | 06:15 PM
jameswwt's Avatar
Hi Mellon Racing,
can i go for FIC 850cc injectors?
Thanks
