HKS GTII 7460R -> external wastegate?
Old Jul 7, 2012 | 06:26 AM
KOOLER's Avatar
Damn! HKS does not sell service parts so looks like I have to dump this turbo and go other one... Just b/c tiny piece of iron does warp
Originally Posted by 94AWDcoupe
THe flapper on HKS turbo is 42mm. The mitsubishi 10.5 flapper is 40mm. I also measured bearings to see if shaft and bearing from mitsu turbo can be used. The HKS bearing is larger in diameter. So fitting the mitsu bearing and arm would not be easy. The 40mm will cover the bigger ports on HKS. But I think 34mm will be too small.
Old Jul 11, 2012 | 06:41 AM
KOOLER's Avatar
OK, tiny update... I have a KAI version But it does not change much. Problem is - flapper itself sitting on the arm has TONS of movements. Actually it simply shakes. 3-4 mm at least. Should it be like this or no?
spdracerut
Mar 28, 2017 12:30 PM
5LEEPERISAH23I
Apr 15, 2010 07:47 AM
kemoly
Sep 19, 2008 01:10 PM
AZ EVO IX MR
Sep 10, 2006 08:07 PM
brandonbigdog
11
May 3, 2005 06:54 AM
