What cams to go with these days?
Old Jun 22, 2012 | 07:09 AM
Ludikraut's Avatar
Originally Posted by R/TErnie
Dual springs lose their damping ability as they wear in. Should be serviced more frequently than they probably are. (service = replaced)
I like the Kiggly's or PSI.
So on a higher lift cam, like a Kelford 272, GSC S2 (or if I'm really lucky, something like a GSC "S2R") spinning out to ~9200 RPM:
- What would you recommend as a service interval on dual springs
- Would you still go with Kiggly's - and why?
I am going to be looking to go to a higher lift cam when I finally get my paws on an EFR, so looking at possibly redoing the springs at that time wouldn't be that big of a deal. My supertech duals probably have about 10-15K miles on them.
l8r)
Old Jun 22, 2012 | 10:58 AM
R/TErnie's Avatar
I don't think any of the other spring manufacturers put in the effort or Engineering time to develop a spring specifically for the 4g63... and their testing probably didn't include running those exact springs on their 8 second race car. As far as why I run the Kiggly springs, I know Kevin is a like minded Engineer to myself and I can see all the development and testing that he put into these springs and what he uses them for. I think I trust his work and the time he put in over an OTS option.... with maybe a vendor backing that brand.... which that vendor probably doesn't approach the problem with the same testing and engineering that Kiggly has put into these springs. That's not a quantitative answer or an answer based in Physics, but it's my honest answer.
Valve springs are service items, and their rates do change. A good spring will maintain its rate for longer than a poor spring.
If you wanted to go nuts, you could get some Titanium valve springs from RCS
Old Jun 22, 2012 | 11:17 AM
boostedtres's Avatar
lots of great advice in here regarding vavles etc, so i wont go there as it is not something I am very well informed in.
cams id go with the S2s and get some supetech Ti springs, seats, and retainers and call it a day! will provide goo mid range power but not drop off up top like some of the other cams. give you plenty of room to "grow" into a red or BBK, but wont be overkill for the street.
cheers and gl with the build brotha
Old Jun 23, 2012 | 04:36 PM
L888Apex's Avatar
Good info so far, so the S2's have a 11.2 lift? Isn't that the same as the Cosworth M2's? Or are they 11.0 flat? I forget
Old Jul 10, 2012 | 04:55 AM
EvilTechnology's Avatar
What did you decide to go with?
Old Jul 10, 2012 | 04:52 PM
foxbear2277's Avatar
I also think you cant go wrong with gsc s2s Good luck with your choice
Erik@MIL.SPEC
EvoX 'For Sale' External Engine / Power
25
Sep 15, 2015 11:07 PM
Aby@MIL.SPEC
Evo X Dyno Results
19
Oct 9, 2014 06:44 PM
Revobasher
Dec 25, 2011 11:39 AM
1QYK9
18
Aug 18, 2008 01:02 PM
