What Trans/T-case/Dif fluids to run and how much?
I am thinking of using AMSoil products. I will be buying fluids this Friday and would like to know what i should use. Also how many quarts.
Thanks
Thanks
I am paranoid about using thin oils so I use Amsoil ARO premuim protection 20w50 in the motor (Built 2.4L and stock) and now Severe Gear 75-140 in the trans and T/C. I do not want teeth torn off the gears when I install my 6262 like my DSM used to do regularly on standard 75-90 gear oil. Engine 5Qts and 3 for Trans and 1 for T/C. It is a little over $100 for the oils.
Here you are and yes people use Amsoil but your not saving your car from a life of torture and torment by not using it
https://www.evolutionm.net/forums/ev...uantities.html
Close to 3 qts in the tranny.
Little over half a qt for each the tcase and rear diff.
Best way to do it is fill until it comes out the fill hole, drive it around and re check the levels.
From: Why do they always call the Evo the Dark Side?
