Will reducing IC size improve Turbo Response?
Old Jul 5, 2012 | 09:10 AM
jameswwt's Avatar
Hi,
just wonder will using a smaller intercooler improve turbo response?
Im currently using 600 x 300 x 70mm ic size.
Plan to switch it to 600 x 250 x 70mm or Stock Evo 6 IC...
On a GT3076R / GSC S2
Pls share.
Thanks
Old Jul 5, 2012 | 09:55 AM
GTijoejoe's Avatar
Will, is a hard answer, can, certainly.
But it can also cause a larger pressure drop across the core so the answer to your questions is very dependent on your setup.
Old Jul 5, 2012 | 10:02 AM
evodriver49's Avatar
i have a 3" injen fmic and they claim that theres only a .01 psi pressure drop which is very impressive for its size, and i can vouch for them as i had no pressure drop or turbo lag before getting retuned and also gained power with it!
http://www.speedelement.com/index.ph...mart&Itemid=38
Old Jul 6, 2012 | 05:59 AM
sparky's Avatar
what BOV/DV, James?
Old Jul 6, 2012 | 07:05 AM
94AWDcoupe's Avatar
even really good intercoolers will have 1-2 psi boost drop through the core at pressures evo typically run. cheezy bad advertising designed to increase sales from the gullible unkowledgable crowd.
Old Jul 6, 2012 | 07:07 AM
94AWDcoupe's Avatar
Originally Posted by jameswwt
Hi,
Pls share.
Thanks
thats not enough size change. you wont feel any difference if cores are same desgn
Old Jul 6, 2012 | 07:51 AM
hmm me and my friend both have it and we honestly did not see a pressure drop from our old tunes. BUT when i added my muse licp for example, i went from 25psi tapering to 22 (old tune) to 23psi tapering to 18 -_- the licp created a huge pressure drop
Old Jul 6, 2012 | 08:20 AM
94AWDcoupe's Avatar
25 tapering to 22 is not pressure drop. thats turbo running out of breath. to measure pressure drop you need boost gauge before and after intercooler
adding IC pipe and seeing boost drop is a good thing. that means system is flowing air easier. boost is a reading of how much air is not going through the engine.
Old Jul 6, 2012 | 08:31 AM
youre not understanding me i was comparing the old tune 25-22 to the pressure drop of 23-18psi respectively after the LICP install -_- and yes i also stated that with the IC there was NO drop whatsoever as in the boost was the same as before with no lag neither. and yes im using my defi boost gauge which has been very spot on accuate compared to my tuners computer.
Old Jul 10, 2012 | 05:38 PM
VIIIdriver's Avatar
I haven't seen too much of a difference in pressure drop if any in any of my customer's cars,as long as the parts are relatively close to the same size,i had a 4" ETS intercooler with my stock Evo 9 turbo and i was getting full boost really early and holding 26 psi at 8k as evidenced by an Omni map 4 bar and in car boost gauge,i was pushing 32 psi on 93 oct at the time with Injen pipes.
Old Jul 10, 2012 | 06:11 PM
jameswwt's Avatar
Originally Posted by sparky
what BOV/DV, James?
Ive order Synapse bov and will arrive in couple of days...Hope it help for my staling problem & improve my boost response...
Old Jul 10, 2012 | 06:27 PM
jameswwt's Avatar
Hi, how about if i go bck to the evo 6 stock intercooler?
Old Jul 10, 2012 | 06:57 PM
MOREPSiTEHBETT4's Avatar
he's not getting it, thanks for trying to help peeps; it's frustrating, eh?
Old Jul 10, 2012 | 11:09 PM
at least it was an educated answer ill give him that. just a lil off topic
timmycat
Oct 25, 2016 03:49 PM
LVSBB6
Feb 1, 2016 11:38 AM
jameswwt
Aug 21, 2012 10:36 AM
jameswwt
43
May 4, 2011 06:25 AM
jameswwt
Sep 7, 2010 10:28 AM
