fuel pump upgrade?
fuel pump upgrade?
hi, right now i have a walboro 255 lph fuel pump in my car which is 5 years old,
i have done some modifications since then, like gt35r turbo, gsc s2 cams, 1250cc injectors...etc
it seems to me the car is now running lean..is it time to upgrade the fuel pump and fuel rail?
if yes which fuel pump and fuel rail should i get, i also plan to turn up the boost.
double pumper.i just upgraded mine.i wanted E85 and 93 tunes.everyone i talked to said to get the double pumper for E85.even if you don't plan to use E85 at least you know you won't run lean again.don't see the sense in going from 255 to 300 unless you just wanted silence out of your fuel pump.
Black_EVO_MR
Oct 30, 2016 07:18 AM
DIDYSIS
25
Sep 26, 2010 07:23 PM
