ACD warning light: only fault code 65
Old Jul 8, 2012 | 12:20 PM
foxbear2277's Avatar
Hey guys I have been getting an intermitent acd failure that started last summer. The veicle has 25,240 mls. All three lights light up either while on the highway for a prolonged period of time or when just starting the vehicle. When disconnecting the battery the function is regained but on some occasions it will comeback almost instantly... I have jumped pins 1 and 4 and read code 65 from the dash. I have checked all the acd pump connections (at the pump) all appears to be o.k. Has anyone else had this code stored and if so what was the fix??
Code 65-ABS monitor system - Broken wire or ABS failure
I have no abs warning light illuminated...
ACD fluid level is o.k.
If a wheel speed sensor is faulty would my abs light not be illuminated??
Im thinking I must have a wire partially shorted to b+ or b- which would explain the intermitent nature of this fault... any thoughts?
I have found this in regards to code 65
http://www.lancerregister.com/showthread.php?t=239877
https://www.evolutionm.net/forums/ev...ease-help.html
Advice of where I should look, possible issues or what connector intergrity may have been comprimised with corrosion and what not would be great
I realize there is quite a lot of information regarding the horrid 3 acd lights but not much infor about actual fixes to issues such as my code 65
Any help is greatly apreciated,
Kind regards and thanks in advance,
Chris
Old Jul 9, 2012 | 02:35 PM
Help needed bump
Has anyone had a corrosion issue by the passenger side by the acd unit as mentioned in one of the linked threads... Cause damn, my vehicle has only seen one winter and has only 26,000 mls or so... I cant see it being my issue... every connector I pull apart is a virgin lmao
Old Jul 10, 2012 | 10:41 AM
kikiturbo's Avatar
Originally Posted by foxbear2277
Help needed bump
check the connectors by driver and passenger feet in the footwell... those want to corrode because sometimes water drips slowly inside... I had the same problem on the left side and my wipers went beserk.. could be your problem...
Old Jul 11, 2012 | 03:24 PM
Thank you for the info, I will look here first and report back this weekend
Old Jul 11, 2012 | 03:43 PM
Ryan.Kauz's Avatar
Also, there was a replacement relay for the ACD pump. Think it was a $4 part from Mitsu. They discontinued the old relay due to faults.
Note that it was NOT a recall.
I found this out when Mitsu USA replaced my ACD pump under warranty (allowed under the suspension warranty for some reason).
Old Jul 11, 2012 | 04:06 PM
This is info I would have never stumbled across if it wasnt for you or someone else with that info I will order the relay to be safe, would rather know 100% that its all good Glad yours was covered
Old Aug 20, 2013 | 06:43 PM
Evo9richie's Avatar
So was it the relay? im having the same issue with mine. Sometimes it comes on and sometimes it doesn't. Especially when its really hot and humid it comes on right when i start moving. Let me know.
Old Oct 13, 2013 | 08:09 AM
Replaced the relay and never looked back
Old Oct 13, 2013 | 09:03 AM
Evo9RS1789's Avatar
Do you have the part number for the relay or where you found it? thank you, man!
Old Oct 14, 2013 | 08:41 AM
Evo9richie's Avatar
id like to have that relay as well.
Old Dec 1, 2013 | 06:31 AM
Dont have the part # just picked it up at the dealer.... and that was some time ago now
Old Dec 3, 2013 | 02:40 PM
jrainwater's Avatar
The relay you're talking about is the one on the firewall to the right of the abs module. There are two relays there. The one on the left is for the acd and the one on the right is for the fuel pump. That's the relay you are referring to correct?
Old Dec 3, 2013 | 03:41 PM
Thats the one I replaced and touch wood I haven't had any further issues
spin
Dec 22, 2018 09:21 AM
whitefrs
Jan 28, 2017 09:51 PM
DarkEvo
18
Oct 12, 2015 07:54 PM
Redline-Z
May 5, 2012 01:38 AM
