EGT probe, which cylinder?
Old Jul 12, 2012 | 09:05 PM
fjm9898's Avatar
Hey guys. I have a zeitronix system i want to install and i just wanted to ask which cylinder is the "hot" one i should install the EGT probe on.
Old Jul 18, 2012 | 04:02 PM
LeXcite's Avatar
First to cam gears is good, or first to opposite side. There is a topic with intake manifold tests, it shows that most lean afr at those cylinders, so max temp. will be there ....
Old Jul 18, 2012 | 07:29 PM
WRC-LVR's Avatar
cylinder 2 is where i have mine..supposedly the hottest.
Old Jul 23, 2012 | 05:47 PM
RoMeIX's Avatar
I had been told by a tuner that my best bet was to put a probe into each cylinder to compare the individual cylinders to eachother. It sounds overly elaborate for my application.
Old Jul 23, 2012 | 11:43 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Ideally, the probe should be mounted in the exhaust manifold runner of the cylinder most likely to run the leanest. Based on our 4G63 experience, this would normally be cylinder #1 or #2 and, judging from plug readings, the Evo 4G63 is no different.
http://www.evomoto.com/tech_info.php...3_6&tech_id=15
Old Jul 25, 2012 | 04:13 AM
fjm9898's Avatar
thanks guys
evo2nv79
Jul 12, 2012 10:15 AM
GTVEVO
Aug 26, 2009 07:59 AM
krayzeviet
Automotosports - Illinois
Nov 27, 2006 01:37 PM
SoR
Feb 14, 2005 09:55 AM
Claudius
Feb 28, 2002 01:01 PM
