Noob Question about Limits of Evo MR Transmission
Old Jul 25, 2012 | 09:02 PM
marvix's Avatar
I want to ask you guys if anyone knows the limits of TQ and HP of a Evo MR 6 Speed Transmission?. I use the search but don't get exactly numbers.
My Evo IX is stock now, but soon I get an AMS Intercooler, Tanabe Exhaust, Turbo Outlet, Downpipe, Induction and freaks me out the possibilities of my transmission broke.
A couple of friends tell me about that transmission is too week (a butter transmission they say ) and I should get the 5 speed transmission.
Thanks for your help.
Greetings.
Old Aug 7, 2012 | 10:25 PM
marvix's Avatar
Anyone?
Old Aug 8, 2012 | 06:37 PM
abazaba410's Avatar
Ive read numerous things... It will depend on how you drive.
Are you road racing, drag racing, DD?
Old Dec 14, 2012 | 11:59 AM
marvix's Avatar
I completely forgot this thread. Basically my drive its weekend drive and no road racing or drag racing. Only some trackdays eventually. After all modificatios I do in the car, this reach 300 AWHP and 260 lb/ft Tq.
With that numbers do I have any risk in your opinion?
Old Dec 14, 2012 | 01:33 PM
llDemonll's Avatar
no.
350lb/ft is the range the MR transmission starts to get sketchy i believe
Old Dec 14, 2012 | 01:37 PM
boostedwrx's Avatar
Tons of threads out there. My 6 speed held up fine to 400+ ft/lbs but again I only had a few thousand miles on it at that power level. Only freeway runs too, no autocross or drag.
Old Dec 14, 2012 | 01:39 PM
AreSTG's Avatar
i beat on my MR trans around what you have for power, i had a little more tq. I did a handful of trips to the dragstrip and 2 autox's. it never gave me a single issue.
but if you do treat it like ****, it can give out. and if you do any track days where it gets the trans very hot, it can give out too, even without launching.
i think you'll be fine.
Old Dec 14, 2012 | 03:36 PM
abazaba410's Avatar
x2 I agree
Old Dec 14, 2012 | 03:42 PM
kanovic's Avatar
I got 335ft lbs and it has been grind 3rd for a while. I only do highway pulls no launches or anything. Bought a 5 speed and Jon the process of swapping so I can go and put more power to it.
Old Dec 14, 2012 | 04:44 PM
EvocentriK's Avatar
Technical torque limit is 295 ft/lbs. People have blown 4th gear with pretty low tq numbers but depends on gearbox history and maintenance and how you drive. I run lower boost in 4th-6th gears to keep tq low.
Old Dec 14, 2012 | 07:33 PM
Yiyo's Avatar
I have 388hp 410tq with 6 speed trans and run 11.7 116 mph
Old Dec 15, 2012 | 03:44 AM
marvix's Avatar
What maintenance have you do in your transmissions?
I only do the maintenance of owners manual, with OEM fluids, do you use any particular oils or friction modifiers?
Greetings.
Old Dec 15, 2012 | 03:46 AM
Yiyo's Avatar
Nothing especial only oem fluid.
Old Dec 15, 2012 | 06:57 AM
EriCS's Avatar
Ive been running at least 350whp on my car depending on which tune I use for the past 35/k miles. I have used only Oem fluids and have done scheduled tranny fluid changes. I do not launch this car and have done plenty of street pulls and 1 road racing day. It has held up fine and plan on doing more track days this upcoming season. At the power level your going to be at you have nothing to worry about. Also 1-3rd gear are the same gears as the 5 speed it just that fourth is a thinner gear to accommodate the additional gear. Do some research and listen to those who have these trannies and at what level there was failure was at if any. Any tranny that can hold up to almost double the power level at stock form isnt necessarily a bad one. Take care of it and you'll be fine. There more stout than most people believe.
Old Dec 16, 2012 | 12:17 AM
fireroasted's Avatar
I am putting down around 330 and beating on it at track days. There are a couple of killers:
Heat
Impact (launching)
Clutch
Heat comes from track days. I built a custom trans cooler setup to address this.
Impact from launching is just slamming the gears with the force of suddenly throwing the car forwards. I don't drag race, but it's logical that the 6 speed with slightly thinner gears isn't the best choice for that application
Clutch is one peolpe don't talk about but I have learned that proper adjustment of aftermarket clutch is actually pretty rare. Once I got it right it was night and day. Often your gears don't break, but your syncro a get damaged, ad that is more of a sign of release issues than gear strength.
At your intent and power level you are fine. Proper maintenance and good clutch adjustment so there is absolutely no drap and you are good,
blackandredgts
May 2, 2017 07:16 AM
J.Js evo9mr
Apr 11, 2017 10:39 PM
sest1412
For Sale - Part Outs
Mar 6, 2017 08:12 AM
MRblack06
Sep 8, 2014 06:47 PM
SupraSkylineSTI
26
Apr 21, 2010 11:45 PM
