GSC S3 vs. Kelford 280
Hey guys,
I bought a ported head, and when the head is off I would like to upgrade my cams from S2s as I have a 2.4L and have seen/heard that there's little loss down low by switching to 280s.
I originally wanted to pick up S3's, however, I have a great opportunity to pick up some Kelford 280s. I'm aware that S2's are very similar to Kelford 272's, so I wanted to see just how similar Kelford 280s are to GSC S3s.
Any input is appreciated!
Thanks!
Thanks!
This doesnt exactly answer your question, but it should give you some insight:
On my 2.3L / e85, i went from k272's > k280's > S2's
The k280's made more top end, but lacked a lot of the "torque hit" of the k272's
on my car, the S2's were "middle of the road" between the 2 kelfords = more top end power than than the 272's, SLIGHTLY less tq than the 272's.
I couldnt find a power compare readily available in my data folder, otherwise i would have posted it.
Hmmmm.
If you can get Kelford 280s for a good price, I'd go for it. Strokers work great with big cams. May also look into Tomei 270s or 280s which MAP has for a great price if you PM them, nice 11.5mm lift on either set.
The Kelford 280s have 11.5mm of lift as well!
Hurrr.....
S3's have 280 advertised duration with 11.5mm of peak lift.
K280s have 280 advertised duration with 11.5mm of peak lift.
http://www.maperformance.com/gsc-pow...sc-6008s3.html
http://www.camshaftshop.com/products...tid=1056#specs
They're extremely similar cams, I just wanted to see if anyone had a performance comparison between the two.
I'm already on the fence about 280s in general in a damn street car I'm sure those 288s are ridiculous.
Hurrr.....
S3's have 280 ADVERTISED duration with 11.5mm of peak lift.
K280s have 280 ADVERTISED duration with 11.5mm of peak lift.
S3's are 11.7mm lift. I have the cam card from GSC stating as such.
-read this-
https://www.evolutionm.net/forums/ev...d-updated.html
Enjoy.
-read this-
Enjoy.
The hard numbers in the cam thread are up to date and VERY accurate. Just some more info to arm yourself with in your decision. I run s3's in my toy and love them. Very well mannered, and NASTY out the top.
