Only 28psi??
Old Aug 10, 2012 | 06:57 AM
sparky's Avatar
The spring in the stock actuators, unpreloaded, usually allows the flapper to go full open in the 8-11 PSI range. The FP 18# HD WGA, unpreloaded, lifts the flapper full open by 14#. The FP 25# HD WGA goes full open by 18 PSI of boost pressurre, unpreloaded.
So, by switching from a stock MHI actuator to the 25# FP unit you are gaining roughly 10# of base spring pressure right off the bat.
Old Aug 10, 2012 | 07:33 AM
sparky's Avatar
EDIT: i deleted this post as i had written it on my iphone while driving and it made no sense to me whatsoever once i reread it.
Old Aug 10, 2012 | 08:56 AM
selp's Avatar
Stock wastegate. Replace the spring, or do the spring mod and that might get you a spike of 32psi. Don't expect to hold anywhere near that. I hope you are also on ARP head studs and bolts.
Benja
10
Mar 2, 2014 05:03 AM
JamaicanEvo
94
Dec 24, 2012 09:27 AM
saltydog
Aug 26, 2012 08:42 AM
big block ix
Feb 20, 2009 01:21 PM
Nomad4g63
20
Jun 10, 2008 01:11 PM
