building Ultimate 5spd
Old Aug 7, 2012 | 01:08 AM
4ukc's Avatar
ppl can you please help me, I have regular 5spd tranny, and I would like to get ultimate 3rd, 4th and 5th gears, what parts should I buy and change?
I mean should I change only gears sliders and syncroes or input shaft and other parts also (can I just install them from Evo9tranny)?
thanks!
Old Aug 7, 2012 | 08:59 AM
Mauricio Evo IV's Avatar
thanks!
You can buy a rebuild kit in Shep transmission...
Old Aug 8, 2012 | 04:37 AM
4ukc's Avatar
thanks I know that, my question is how I can do it but not where to buy it
Old Aug 8, 2012 | 08:10 AM
laramie_05MR's Avatar
You only need to change the gears. Hubs, sliders and shafts are the same. Check the FSM to see if you can reuse the hubs/sliders. You should replace the syncros while you are in there as well as installing double wall roll pins. Make sure you set the preload on the bearings a little tight to improve high rpm shifting. If you really want you can drill and safety wire the roll pins. That's all I can think of at the moment.
Old Aug 9, 2012 | 02:04 AM
4ukc's Avatar
thanks a lot!
kartectuning
12
Nov 17, 2022 07:44 AM
Yang_2012
Nov 12, 2013 03:52 PM
Gazika
Sep 19, 2013 09:42 AM
porsherules911
May 14, 2008 09:28 AM
UpstateEVOVIII
Oct 15, 2007 04:11 AM
