Boost leak? need help!
Old Aug 18, 2012 | 12:12 PM
Evolicious8's Avatar
About a month ago I cleaned my throttle body, i guess i did not tighten up the clamp tight enough and my upper intercooler hose popped off a couple of times, i got a brand new clamp and that fixed the issue. Now every time i get on boost and get right at 4k rpm i feel like the engine over revs and goes no where. My boost gauge reads about 20psi so im clueless on what the issue might be no CEL.
Old Aug 18, 2012 | 12:20 PM
Drifting Away's Avatar
Well what psi are you tuned for is the first question.
Second, did you perform a boost leak test?
Old Aug 18, 2012 | 12:38 PM
Not tuned, and havent performed a boost leak test dont think i have the right equipment for that. Might have to take it to a shop and have them perform a boost leak test.
If my boost gauge is reading the right boost would a boost leak still be possible?
Old Aug 18, 2012 | 02:57 PM
Raped's Avatar
Yes, it is still possible that you have a leak. Any time after I change or modify any intercooler pipes I like to boost leak test my cars. You can make a tester for little cost, or you can buy one online. It will certainly be a lot cheaper than taking it to a shop.
Old Aug 18, 2012 | 03:26 PM
TeachersEvo's Avatar
sounds like a slipping clutch.
if the car is going no where but the engine is still revving it means the clutch isn't grabbing, usually.
Old Aug 18, 2012 | 05:19 PM
Thats not a bad guess either. Do you smell clutch when the window is down? and have you launched your car recently....
Old Aug 18, 2012 | 05:55 PM
Frew's Avatar
If the clutch was bad would he be hitting 20 psi? Since the engine would not be getting proper load.....
Old Aug 18, 2012 | 06:06 PM
4RETECH's Avatar
Yes. With a 2-step you can build boost..... Clutch means nothing, LOL
And yes, I believe the OP has a clutch problem.
Old Aug 18, 2012 | 11:20 PM
I did launch the car about a couple of weeks ago, and i did get that burnt clutch smell real bad, and ive noticed my clutch pedal is real hard compared to other cars ive driven lately. Never really experienced a slipping clutch would it feel like the engine over revs inbetween a shift?
was really hoping it was not my clutch
smanji
May 15, 2017 01:57 PM
jimbo74
Lancer Troubleshooting
Apr 25, 2017 05:41 AM
Billy's MR
Feb 28, 2017 08:00 AM
Cajun Power
69
Oct 17, 2015 12:52 PM
Derek888
Jan 18, 2007 09:29 PM
