For all those with a CEL and no cat
Old Jul 22, 2004 | 11:04 AM
  #46
Volunteer's Avatar
I did mine a month ago and I have 1200 miles and so far its working like a jewel. I have the Helix cat-delete/Race pipe.
Originally Posted by EvoPyro
sorry for bringing back an old post but has everyone still had goodluck with this, im about to do it and hope it works.
Old Jul 22, 2004 | 03:52 PM
  #47
EvolvedDSM's Avatar
Working just fine here
Old Jul 23, 2004 | 06:02 AM
  #48
992gnt's Avatar
My first post in this thread was on April 5th. No CEL since, which includes a couple of track days and a 600 mile trip. Not to mention almost 6000 miles since then.
Old Jul 23, 2004 | 06:07 AM
  #49
tweakdsm's Avatar
www.o2simulator.com $30 shipped. easy to install - i got it, no problem
Old Jul 23, 2004 | 06:15 AM
  #50
MayhemSi's Avatar
I have used these before on other vehicles with good results as well. Cheap and it works.
Old Jul 23, 2004 | 06:59 AM
  #51
Noize's Avatar
EvoM Administrator
Two months antifoulers and 3000 miles, zero CELs. Cost me all of $4. Thanks for tipping me off to this thread, Joey!
Old Jul 29, 2004 | 03:08 PM
  #52
Guack007's Avatar
Where on the 18mm Spark Plug Anti Foul Adaptor do yo0u drill the hole. Can I use my 1/2" drill bit and just go at it. I dont understand whats so hard about the drilling part and why its so important to do it right. How can it be done wrong? Any tips?
Old Jul 29, 2004 | 03:54 PM
  #53
992gnt's Avatar
There is a hole already in the bottom of the adapters. The hole is ~1/4" in diameter, you just need to drill it out larger. The tip of the o2 sensor will fit through the hole, as it's just a bit longer (deeper) than the adapter. There's no trick to drilling it, except to make sure it's centered so you don't weaken the threads. Only drill out one adapter, leave the other one as-is. Assembly goes like this:
Pipe <- undrilled adapter <- drilled adapter <- o2 sensor
Old Jul 30, 2004 | 10:51 AM
  #54
Guack007's Avatar
Smile
Thnx for clearing things up for me
Old Aug 2, 2004 | 01:56 PM
  #55
Cash Money's Avatar
I'm in going to purchase prolly the Buschur turbo back and i hate cutting and hacking wires, especially O2 wires ...Glad to see this trick works, was planning the same thing... the Helix testpipe has a "similar" set up... i didn't wanna mix and match the buschur dp, helix tp, buschur catback... thanks for the great posts guys...
Old Aug 2, 2004 | 02:06 PM
  #56
tsi90awd's Avatar
I take out my cat before driving to a track event, then put it back in when I get back home. I spaced out the O2 sensor using the two adapters described in this thread.
I've had the CEL come on twice after about 300 miles of driving ( I live a long way from any tracks!). Disconnecting the battery resets the ECU and the light goes away. At least on my car, this fix works most of the time, but not all the time.
Old Aug 15, 2004 | 09:14 PM
  #57
MitsuJoe's Avatar
just installed this in my car, I will keep everyone posted
Old Aug 17, 2004 | 12:35 PM
  #58
hawjdude's Avatar
Was thinking about buying the helix testpipe, are there any problems of cel with anyone using it. Thanks.
Old Aug 18, 2004 | 06:39 PM
  #59
TampaTurbo's Avatar
My lord, the Perrin CEL eliminator works perfect, I installed it myself and I am about as retarded as you can get. No problems. Easy instruction. One complaint I have about the piece is that they dont give you enough wire coming out of it to splice into the existing O2 wiring. Grrr. Nothing a retard cant handle. =)
Old Aug 18, 2004 | 11:22 PM
  #60
naucrx's Avatar
Ahh, I just installed my UR test pipe. I had to extend the o2 sensor wiring so that it would reach the bung in the test pipe. I have about 100 miles on it and quite a few WOT pulls and so far Zero CELs!
I believe the UR test pipe and the Helix are the same design.
