For all those with a CEL and no cat
Old Oct 8, 2004 | 06:39 AM
  #76
evo 8 ya's Avatar
Originally Posted by tsi90awd
I put the stock catcon back in.
what's a catcon?
Old Oct 8, 2004 | 11:13 AM
  #77
Volunteer's Avatar
I have an RMR 3 inch turbo-back exhaust. For street use, I put the stock catcon back in. For the track, I install a straight pipe. I installed two of the adapters in the spring to space out the O2 sensor.
I occasionally get the CEL coming on with both the straight pipe and the stock catcon, but it is only when cruising (constant speed) at about 95 mph. When this happens, I disconnect the battery to reset the ECU and the light goes a way. It is a bit of a pain, but seems to work. It's not too often that I get to run at a constant 95 for a few miles!
Anyway that is my experience with this fix.
Is it me. Because none of that statement make sense to me.
Old Oct 8, 2004 | 11:42 AM
  #78
tsi90awd's Avatar
Sorry for being too terse.
A translation:
catcon = CATalytic CONverter
This thread is about the CEL (check engine light) that comes on when running a straight pipe (test pipe) instead of the catalytic converter, or sometimes when using a high flow catalytic converter. A commonly discussed fix for this is to space out the second O2 sensor after the catalytic converter using two sparkplug antifouling adapters (or spacers).
I'm using a exhaust system with a 3 inch downpipe and 3 inch catback. On the street, I usually install the stock catalytic converter into the exhaust system. When I go the race track, I replace it with a 3 inch straight pipe. This is pretty quick - only takes about 15 minutes. Putting in the anti-fouling spacers hasn't always worked for me in stopping the CEL from coming on.
When I drive a constant speed of about 95 mph for 5 minutes or so, I will usually get the CEL coming on. This happens whether I have the stock catalytic converter or the straight pipe in. The key characteristic is that I have to be at a constant high speed (not accelerating or decellerating) for this to happen.
Just letting people know that the spacers may not be a universal fix for all driving conditions. Or, it might just be a characteristic of my car. Does this happen to anyone else?
Old Oct 8, 2004 | 01:58 PM
  #79
Volunteer's Avatar
A translation:
I'm with you now. I have the Helix cat-delete pipe for the last 10k and this fix. Its worked flawless. I've never went back to the stock converter or alternated them so I don't have any experience with that.
Old Oct 10, 2004 | 10:01 AM
  #80
sylvester31's Avatar
so this is how the adapter should look after you drill it, i've had problems with the cell for a while now.
thanks a lot for this thread, it was very helpful.
Old Oct 10, 2004 | 12:03 PM
  #81
EvolvedDSM's Avatar
A translation:
Have you pulled the code to confirm its related to the cat? I've used the spacers with both the test pipe and stock cat w/o any troubles. I'd be fairly comfortable saying it might be another code.
Old Oct 10, 2004 | 08:58 PM
  #82
suuteki's Avatar
i tried it, as long as you drive a constant speed it works but once you step on that gas pedal gear to gear it will come back on for some reason.
Old Oct 10, 2004 | 10:16 PM
  #83
umiami80's Avatar
Me too, and I have a 02 simulator on, I am doomed.
Old Oct 10, 2004 | 10:20 PM
  #84
w2pac12345's Avatar
I did the mechanical o2 fix and it worked... so far over 1000 miles with it and no cel.
Old Nov 17, 2004 | 05:00 PM
  #85
sophic's Avatar
This didn't work for me, and I have a high flow cat, and the car DOES go in to limp mode.
Old Nov 17, 2004 | 05:04 PM
  #86
MYEVOVIII's Avatar
I have seen the Mechanical )2 fix work on 6 Evo's in my area some with12k since install and have yet to have a CEL. Are you using one or two spacers the guys here have been using two instead of just one and it works like a charm
Old Nov 17, 2004 | 05:31 PM
  #87
MitsuJoe's Avatar
Originally Posted by Joe's_EVO8
just installed this in my car, I will keep everyone posted
Well I got the pesky P0420 again! I have only installed one, two of them would make it too long and would stratch the wiring too much. Any ideas?
Old Nov 17, 2004 | 05:34 PM
  #88
MYEVOVIII's Avatar
Two have fit on many of the guys here exhaust's from Vishnu and Buschur and RMR and HKS and have no problems the wire. It is very long just undo the bendable wire holders and reposition then bend back.
Old Nov 17, 2004 | 06:42 PM
  #89
sophic's Avatar
BR Turbo Back. I tried 1 and two spacers, no luck.
Old Nov 17, 2004 | 08:55 PM
  #90
umiami80's Avatar
My light has been on for over a year, I hate that BS when teh Vendor GUARANTEES no light, then I get A Light and they say "Welp, about 10% of our customers get that, oh well"
