For all those with a CEL and no cat
Old Aug 19, 2004 | 09:27 PM
  #61
LateSleeper's Avatar
I went to my local Murray's parts store. They had two styles of 18mm anti-fouler plug adapters. These were Motormite part numbers 42002 and 42009. They describe 42002 as being tapered. Which one do I want?
Old Aug 21, 2004 | 06:31 PM
  #62
Nez136's Avatar
Just Installed 18 mm Adapters, took 15 minutes total, haven't seen CEL (It was on for 8 months) , i am very happy , thanks guys
Old Aug 31, 2004 | 09:20 PM
  #63
GVR-4's Avatar
Thanks Derek!
I've been fighting a CEL for the last several weeks and the anti-fouling adapter mod is working.
Just a note to add to Dereck's, make sure you get the adapter that uses a gasket and not the tapered seat.
Mark
Pina Motorsports 3" turbo back
Old Sep 21, 2004 | 11:21 AM
  #64
caymandiver75's Avatar
Also to note.... what can be done to make sure these don't turn into a glob of rust?! I can only think that spraying them with high heat paint is the only option and i'm not even sure how well that will work with the high heat and excessive moisture it will be exposed too.
Old Sep 21, 2004 | 02:04 PM
  #65
Volunteer's Avatar
The majority of anti foul adapters are aluminum, you don't need to paint them or do anything to them unless you want. The other thread posted today the guy is using plumbing pipe hardware for his, I'm not knocking it. It will just rust very badly if its not painted.
Old Sep 29, 2004 | 11:06 PM
  #66
ultraflip's Avatar
bringing back an old thread... has anyone eliminated the rusting issue for this mod?
Old Sep 30, 2004 | 03:20 AM
  #67
there should be no issue with rust as most of the connectors are all aluminum.
Old Sep 30, 2004 | 04:42 AM
  #68
SuperHatch's Avatar
Originally Posted by SuperHatch
I used the Perrin simulator and I havn't had the CEL come on in 800 miles. The CEL came on in 10 miles after installing the turbo-back without putting the simulator in. So I'd say the simulator fixed the problem for me.
- Steve
Update...
Still no CEL, 10k miles since I installed the simulator.
- Steve
Old Sep 30, 2004 | 05:53 AM
  #69
evo 8 ya's Avatar
I too would like to know this
Old Sep 30, 2004 | 06:18 AM
  #70
VTECH8TR's Avatar
I tried this and it didn't work for me. I had to install an 02 simulator to fix my problem.
Old Sep 30, 2004 | 07:16 AM
  #71
evo 8 ya's Avatar
I just went to get the adapters and the 42009 is the one that should work. hopefully
Old Sep 30, 2004 | 08:08 AM
  #72
Yes... I got the non tapered, 42009 adapters also. I've had it on now for a week, so far no SEL. I was only able to use one adapter because of the catback bung being angled. We shall see.
Old Oct 7, 2004 | 06:00 PM
  #73
suuteki's Avatar
Hey you're a saviour timzcat!
Old Oct 8, 2004 | 06:00 AM
  #74
evo 8 ya's Avatar
Yea man. I've had mine in for a week and no CEL
Old Oct 8, 2004 | 06:31 AM
  #75
tsi90awd's Avatar
I have an RMR 3 inch turbo-back exhaust. For street use, I put the stock catcon back in. For the track, I install a straight pipe. I installed two of the adapters in the spring to space out the O2 sensor.
I occasionally get the CEL coming on with both the straight pipe and the stock catcon, but it is only when cruising (constant speed) at about 95 mph. When this happens, I disconnect the battery to reset the ECU and the light goes a way. It is a bit of a pain, but seems to work. It's not too often that I get to run at a constant 95 for a few miles!
Anyway that is my experience with this fix.
