Low speed whistling noise?
Old Aug 30, 2012 | 07:56 PM
MyronGainz's Avatar
It was raining pretty heavily a week ago and I had to drive through some water to get to work. Ever since then, I've been having the hardest time chasing down this noise from the front-left side of my car.
I've played with the windows enough to isolate it to the front-left area being the loudest, and it seems to be most apparent when driving against a wall. But the noise seems to be an intermittent whistle, almost like a bird chirp, or the sound you get when your rotor is warped and there's a high spot making contact with the pad.
So far I've ensured a few things:
  1. The rotors are not warped
  2. There is nothing underneath the disc pad/the shields are not making contact with the wheels
  3. The tires have no defects/shapes/etc.
  4. The front wheel bearing (in the opinion of an independent mechanic) doesn't exhibit the symptoms of failure as the noise tends to go away after 50-60mph, and it doesn't have the same loud groan
  5. The clutch/transmission assemblies are unrelated because the noise isn't affected by neutral/gear, clutch in/out, engine on/off
I've pushed the car down the road to no avail, it doesn't really start making noise until about 10mph. I have an appointment to get the car thrown up on a lift on Saturday, but I was hoping someone would have an idea or two to throw out.. Or at least give me a good idea where to look while underneath!
Old Jul 17, 2015 | 08:57 AM
Insanenoodle's Avatar
hey sorrry to raise this from the grave but did you ever figure this out? My '05 does exactly what you describe.. Most apparently when driving next to a high curb or a wall. I thought maybe the brakes were dragging but there are no other symptoms to indicate that...
The noise is like a whistle/light grinding noise..
GrannyShifting
Mar 21, 2017 05:25 PM
commbubba19
Oct 11, 2016 07:37 PM
jayree41
10
Nov 23, 2015 11:24 PM
Ayyrock
Jul 20, 2015 04:47 PM
AlexGutEvo8
May 24, 2015 11:35 PM
