Help choosing a turbo for a DD
Old Sep 1, 2012 | 10:22 PM
Z06Samuel's Avatar
Hello guys,
Looking to make 400 whp max (cams and supporting mods on 91 octane) and have a close to stock spool for the street. I am looking at either a full ported BBK or ported FP Green. Any help or other recomendations with be greatly appreciated.
Thank you,
Sam
Old Sep 1, 2012 | 10:25 PM
fastyouth1313's Avatar
MAP EF2 or EF3
Old Sep 1, 2012 | 11:02 PM
YogSaahoth's Avatar
Veteran: Army
FP 71hta
Old Sep 1, 2012 | 11:06 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You're in CA, so my vote goes for any of the stock frame turbos.
Personally, I run the BBK Full.
Old Sep 1, 2012 | 11:21 PM
tscompusa's Avatar
bbk full or a 71hta. pick your poison.
Old Sep 2, 2012 | 05:42 AM
Craig King's Avatar
Originally Posted by YogSaahoth
FP 71hta
x2
Old Sep 2, 2012 | 09:07 AM
Z06Samuel's Avatar
Thank you guys, I will put this info to good use!
Sam
Old Sep 2, 2012 | 10:00 AM
sparky's Avatar
Originally Posted by fastyouth1313
MAP EF2 or EF3
Do the MAP EF3, and EF2 turbochargers use the stock MHI housings? They are both totally stock appearing? I just wasn't sure, Thanks!
Old Sep 2, 2012 | 10:12 AM
sparky's Avatar
I am considering a current generation BB Green with a 9.8cm housing. Because my RS has JDM shorty close ratio gearing and even my OS Green didn't quite spool quick enough in 1st through 3rd.
My JB Red configured with a standard 10.5 is too slow spooling for the twisties. As an economy alternative I may just send a 9.8 housing into FP and have it cut for the Red turbine wheel though. This in the meantime until I save up enough mazuma for a BB Green.
So, to the OP, I would vote BB Green, or, BB BBK-B(3B). This will give you a wee bit of headroom over 400 on 91....but that's OK isn't it?
Of course, as Golgo states, the totally stock appearing BBK is hard to beat for CA on 91. It will get you to 400 (but barely) on 91
Old Sep 2, 2012 | 10:27 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You really gotta work to hit 400whp on 91.
This is the car I modeled my build after:
https://www.evolutionm.net/forums/ev...tephra-v7.html
Old Sep 2, 2012 | 10:38 AM
sparky's Avatar
IX's are khuuul! A similarly modded VIII wouldn't have done it I guess. The linked build has everything except the head ported. It has healthy cams and the MAF removed. Albeit it is running through a hi-flow cat on 91. That is a really nice stealth build and a great tune on a notably stingy dyno.
Old Sep 2, 2012 | 10:55 AM
sparky's Avatar
I guess that over 400 with the BBK-Full on straight 91 through the MAF sensor would be hard to achieve at least on that Mustang dyno. The switch to SD which eliminates the high end airflow restiction netted 15 WHP alone. So, would 375-385 Mustang WHP be more a realistic limit with the BBK-Full on 91 with a cat and through the MAF?
Old Sep 2, 2012 | 12:58 PM
scheides's Avatar
EvoM Moderator
BBK full or ef3. Ef3 will probably have an anti-surge cover in it tho so you might want to do the ef2 instead.
Old Sep 2, 2012 | 01:30 PM
Craig King's Avatar
EF3 seems like overkill if OP is shooting for 400hp max. EF3 will do 450+
Old Sep 2, 2012 | 01:37 PM
scheides's Avatar
EvoM Moderator
Depends on the dyno--I'm surprised nobody has mentioned or asked which he is talking about
