Why suddenly Timing jumps around during idle logging?
Old Sep 13, 2012 | 09:10 AM
jameswwt's Avatar
Hi,
just curious why does the idling timing jumps around?
My timing map at 1000 rpm til 60 load cell is 15 deg and my evoscan used to log 15 deg of timing during stationary/idle but now the timing kept jumping around during idle.
Any idea???
Old Sep 13, 2012 | 09:52 AM
Raptord's Avatar
I think it's normal for timing to jump around at idle as the ECU uses timing adjustments to maintain your idle rpm.
Old Sep 13, 2012 | 09:59 AM
jameswwt's Avatar
Oic...Thanks Raptor but most of my previous logs, my idle timing is always constant at 15 deg as set.
Just wonder will a bad cam sensor cause such problem?
Old Sep 13, 2012 | 11:58 AM
Raptord's Avatar
If the idle rpm was higher in those logs, maybe it wasn't triggering the ECU into "idle mode", therefore not using timing to maintain a steady rpm? This is just a theory.
Old Sep 13, 2012 | 06:36 PM
jameswwt's Avatar
+1 Raptor...
Viegasjuice
Jan 10, 2014 08:29 AM
mrm95
Dec 7, 2013 11:02 PM
4G63 4EVR
May 18, 2012 09:38 AM
xhomm02
Nov 24, 2010 10:26 AM
xhomm02
38
Dec 29, 2009 05:27 PM
