need help asap no spark no fuel from injectors no start
Old Oct 6, 2012 | 07:42 PM
  #31
scrivs's Avatar
It's an 8... I'm hoping its just one of the tensioner bolts... Don't think I put sealant on them...
Old Oct 6, 2012 | 09:13 PM
  #32
jason42003's Avatar
ok that eliminates the mivec line, took me forever to get that to stop leaking, did you use an oem gasket between the block and the oil filter housing. I used a gasket material there but it was leaking bad till I replaced that with oem. check all of your seals in that area and what not but if its a real bad leak I don't think it would be leaking past the bolt that fast. make sure it is the engine oil too, mine had a ton of leaks when I put the new engine in, sealed off the ones on the engine n thought i was good, then I drove it a lil and still had oil drip. turns out it was a seal in my xfer case slinging oil cuz the seal to the tranny was leaking too much in. either way smell the oil, if it smells real sweet then its gear oil n leak is there, no smell or burnt smell is engine n leak is there.
Old Oct 6, 2012 | 09:16 PM
  #33
jason42003's Avatar
o and when you put on your valve cover did you use rtv in the corners of the gasket. I know it's far away but when things are revolving as fast as the timing belt stuff is it tends to fling it. Not saying any of these things are it for sure. Just trying to give suggestions where to start looking since I can't really look at the car n tell you for sure.
Old Oct 7, 2012 | 09:03 PM
  #34
scrivs's Avatar
Yup did that. Turned out my brand new no mile hydraulic t-belt tensioner decided to **** the bed. F@#K!!
Old Oct 8, 2012 | 12:31 AM
  #35
jason42003's Avatar
That sux a big one. I've been looking at the solid tensioner they sell for our engines. Its alot more simple than the hydrolic in that its just a bolt that your screw in or out to hold the tension which also gives you more accurate and fine adustments in theory. You might look into that one since you have to replace it anyways, and if you do give it a try let me know how it goes. It's like I said in theory its a great part, but there is a huge difference between theory and real world.
Old Oct 8, 2012 | 03:38 PM
  #36
luvboost's Avatar
Thanks for the help guys, it seems I installed the damned thing backwards... She started right up... Only to find a nasty oil leak coming from behind the lower timing cover (around the crank) . Any ideas fella apart from the t-belt tensioner bolts??
how did the tbelt tensioner fail? it just released presure on the belt?
That's funny your crank sensor was backwards. I literally had the same post a few posts up
Old Oct 9, 2012 | 10:05 AM
  #37
scrivs's Avatar
Ok, I was jumping to conclusions-- the p.o.s machine shop that rebuilt my head forgot the damn cam seals!!
Old Oct 9, 2012 | 11:29 AM
  #38
jason42003's Avatar
Cool
Wow that's awesome, sounds like my engine, has 300 mi on it from break in n its already leaking coolant from the trans side, not much but when u drop 8 grand on an engine u kinda expect it to work.... N don't expect to put half of it together urself. But on the brightside at least you kno wut it is now n is make them fix it.
Old Oct 9, 2012 | 01:01 PM
  #39
scrivs's Avatar
Yeah man, thats how I'm looking at it... Sorry to hear yours is leaking...
Old Oct 9, 2012 | 01:16 PM
  #40
jason42003's Avatar
its not that bad of a leak but I mean u dont have slight leaks when you buy a car so a new engine shouldn't either but maybe im ocd haha.
Old Oct 10, 2012 | 03:25 PM
  #41
luvboost's Avatar
yeah I put everything back together myself. Was the only way I would know if things were done right and if they weren't it was my fault haha.
Old Oct 10, 2012 | 09:58 PM
  #42
jason42003's Avatar
Hahahahahahaha u kno if you lived up here we might actually be really good friends cuz that's exactly how I feel when I put my stuff back together haha. But yeah that n y pay sumone to do sumthing I can do myself, n its always good to learn more bout the car u drive.
Old Oct 11, 2012 | 05:20 PM
  #43
luvboost's Avatar
yeah, I mean I didn't do it alone though cause I don't have that intricate knowledge you need to do things like remembering where every little thing goes, but I did learn a ton about it lol.
Old Oct 11, 2012 | 11:45 PM
  #44
bryonboals's Avatar
I have a question about the crank sensor. I think mine might be bad too. How long did it take to put new one on, and did you have to pull the timing belt?
Old Oct 12, 2012 | 01:22 PM
  #45
jason42003's Avatar
took me maybe 2-3 hrs and yes the timing belt has to come off because the wire and connector route behind it. you couple get around that by cutting the wiring harness in half then splicing it back together once its in place, but I personally don't like to cut into wires if I dont have to.
