Rpm Dropping!! Help
Old Sep 15, 2012 | 02:29 AM
saad601's Avatar
Rpm Dropping!! Help
Hello Boys...
My car is Dropping RPM's Like crazy.... For. Eg...If i pull 3rd gear to an extent where it comes under load and finish my run , put the car to neutral to slow down..the rpm's come down quickly almost to 500 causing the car to stall..
Dangerous at high speed if it stalls...
what do you think is the problem?? is it a mechanical issue causing it or whether its ECU related? (Stock ECU)
Car is Running a 30r with all the basic bolt and GSC'2
Saad
Old Sep 15, 2012 | 10:40 PM
asu11's Avatar
Could be a number of things. Dirty throttle body/IAC, BOV, boost leak, tune, just start checking things out and eliminate some stuff.
Old Sep 15, 2012 | 11:07 PM
Revo15's Avatar
Do a boost leak test and go from there..this is a common problem on all of our evos mostly 8 & 9..anyways do some research there's a lot of threads on Evom about this. Usually the tb shaft seals, Iac valve and Egr valve will commonly cause this. if I were you I'd start checking for a Boost leak and go from there.
clanzkiller
25
Mar 15, 2017 09:55 PM
Lag is Free
15
Dec 11, 2013 08:10 AM
zakdamunky
13
Oct 14, 2013 06:44 AM
foxbat
Jun 25, 2012 08:45 AM
EVO(boss)
Oct 23, 2011 01:49 AM
