Valves Keep Touching Pistons...What to do?
Old Sep 17, 2012 | 02:07 PM
ilikeppie's Avatar
Alright so it seems like I keep kissing the valves with my pistons ever so slightly. I think my set-up just is not working together. What would be the best recommendation to make this work. I have considered looking for a different set of pistons with a deeper relief cut or can the ones I have be cut. Here is my set-up:
Bottom end is all Turbo Tuff:
Manley Crank 94mm
Manley Rods 156mm
Manley Pistons 10.5:1CR
Valve Train:
Cams - Buschur Racing BF272's
Valves - Ferrea +1mm on both exhaust and intake
Supertech duel valve springs
stock lifters
Please let me know your thoughts on this and the best way to resolve the issue. Thanks in advance!
Old Sep 17, 2012 | 02:13 PM
SilverShadow03's Avatar
That sucks...
Are you sure you timed it correctly?
Thicker head gasket....I don't know.
I just pulled my head off this past weekend due to some major valve vs. piston noise....so I was interested in what others may have said...but I'm the first...lol...Head came off and I can't see a damn thing wrong except a possible 'kissing' of my intake valves where the divots on the piston tops are....no clue...hopefully the machine shop can tell me what's wrong...if anything...Regardless a freshened up head with 152K on it will only help!
Old Sep 17, 2012 | 02:22 PM
ilikeppie's Avatar
Yeah my timing is correct it was correct, had some bad valve noise then checked everything couldn't find what the noise was so I pulled the head and found some bent valves and scuffs on the pistons. So I took it in had the valve job completely redone new guides valves everything started it up and still have some valve noise not as bad but still there and I am afraid as I run it they will get worse again.
Old Sep 17, 2012 | 03:12 PM
dillonb's Avatar
if the head was decked to much could of been taken off
Old Sep 17, 2012 | 03:27 PM
ilikeppie's Avatar
It was only cleaned up not much was taken off. Has anyone ran this or a very similar combination before? Where would I get a thicker head gasket? Or would different pistons be the way to go?
Old Sep 17, 2012 | 03:29 PM
blackevolution8's Avatar
I would buy some clay, put it on top of the piston in the valve reliefs, put the head on, time everything and crank the engine over. Then pull the head off and see how much room you have between the valve and piston. You may need to buy adjustable came gears and make sure the cams are at true TDC when the piston is at TDC.
Old Sep 17, 2012 | 03:39 PM
ilikeppie's Avatar
That is where I think I will have to go with this. Luckily I already have the adjustable cam gears I would just have to degree them. Hopefully I didn't already bend these valves again. What would be an acceptable valve to piston clearance?
Shaun@AWDMotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
110
Dec 6, 2016 04:52 PM
SBR INC
Nov 26, 2016 07:39 AM
Seancj
Aug 6, 2015 03:02 PM
CORZA
Jun 19, 2015 09:28 AM
ilikeppie
12
Jun 11, 2012 07:25 AM
