Evo 8 Top Speed?
Old Sep 23, 2012 | 03:04 PM
Randal's Avatar
Guest
Evo 8 Top Speed?
How is the top speed regulated for a stock evo? Drag limited? Or is it cutoff at a certain rpm? What is the topspeed of a stock evo? I have an evo 8 with 400whp. What is the top speed of it assuming I redline it at 7,500 rpm in 5th gear?
Old Sep 23, 2012 | 03:08 PM
sourtowel's Avatar
http://en.wikipedia.org/wiki/Mitsubi...ncer_Evolution
Old Sep 23, 2012 | 03:24 PM
Randal's Avatar
Guest
I read that already. The FQ400 has 400 crank hp so about 350 to the wheels. Top speed of 175Mph. Drag limited? Rpm limited? Or ecu limited. That is what I want to know.
Old Sep 23, 2012 | 04:17 PM
SOUL STEALER's Avatar
Just take a drive. If you hit rev limit easily in top gear yur gear limited. This is the case with my X. If your rpms hit a brick wall in the middle of your power band then it's governor. If you can't figure this out because you run out of road then you are power/aero limited or just not really trying.
Old Sep 23, 2012 | 04:46 PM
Randal's Avatar
Guest
Yeah I am trying to avoid 157MPH on my local highway lol, I am just curious to know.
Old Sep 23, 2012 | 05:08 PM
yahh's Avatar
It's ECU limited and can be removed with ECUFlash.
Old Sep 23, 2012 | 05:24 PM
Randal's Avatar
Guest
Well I have my car tuned.
Old Sep 23, 2012 | 05:35 PM
Just give it a try..... You might like it
If GSP pulls you over just tell them I said it was cool.
Old Sep 23, 2012 | 06:01 PM
Randal's Avatar
Guest
Old Sep 23, 2012 | 08:58 PM
masonh's Avatar
175mph comes at 7500rpm for the stock EVO 8.
175mph comes at 7500rm for the stock EVO 9
192mph at 7500rpm with the 4.11 EVO 8
so to answer it is rpm limited.
Old Sep 23, 2012 | 09:00 PM
masonh's Avatar
considering you have a standard tire height of course
Old Sep 23, 2012 | 09:01 PM
FJF's Avatar
FJF
The stock tune limits the top speed to ~310 mph. Might as well be any number.
Old Sep 24, 2012 | 05:28 AM
PatricksEvilEvo's Avatar
I've had mine over 175, unless I have different gearing this is incorrect. Yes this was on a closed section.
Old Sep 24, 2012 | 02:10 PM
masonh's Avatar
sorry meant 165mph on the EVO 9.
could be gearing or tire diameter or even speedo error as they are rarely accurate and they almost always read at a higher speed.
the mph/rpm chart is listed at several websites and i took the info straight from the chart.
Old Sep 24, 2012 | 02:33 PM
Ev0ikon's Avatar
Mine is limited to under MACH 1.
sterlinge
Nov 14, 2016 08:10 AM
evo9guy
58
Feb 11, 2016 06:34 PM
DMP
Mar 16, 2012 02:05 AM
DeMoNz
Nov 3, 2011 04:51 PM
Fourdoor
72
Jul 24, 2011 12:31 PM
