Exedy triple carbon can't be converted to triple cerametallic? or is it possible?
Old Sep 26, 2012 | 01:34 AM
evotris's Avatar
I heard that you cannot convert the exedy triple to cerametallic? Why not? Or is it possible?
I thought you can just change the disc? I like to keep my exedy but I see a lot of people here are using quarter master 8 leg.
I dd the car and I'm not sure if the QM will last long like the exedy?
Old Sep 26, 2012 | 01:19 PM
evotris's Avatar
Anyone
Old Sep 26, 2012 | 01:28 PM
Lukelis's Avatar
I have the same exedy triple cf and see no problems to convert it to ceramic.
Old Sep 26, 2012 | 10:14 PM
evotris's Avatar
Then a vendor lied to me. He said it cannot be converted to cerametallic at all. Lol (I won't mention his name and co. But he is a vendor here)
Old Sep 26, 2012 | 10:39 PM
420a-t's Avatar
Check the max and min thickness of both types of plates
Old Sep 27, 2012 | 03:29 AM
wisniaPl's Avatar
why want cerametalic instead of carbon?? its rebuilt time??
Old Sep 27, 2012 | 06:42 AM
94AWDcoupe's Avatar
ceramic twins and triples are 200mm.
carbon plates 225mm.
thickness of discs is not the issue.
Old Sep 27, 2012 | 10:33 AM
evotris's Avatar
Yes about to rebuilt. Got it used!
Old Sep 27, 2012 | 05:25 PM
Lukelis's Avatar
Exedy Triple Plate Carbon Clutch Kit - EVO 8/9
Number of Discs Triple
Spring Damper Discs Low Inertia Spider Center
Push / Pull Pull Type
Disc Outer Diameter 200mm
Attached Thumbnails Exedy triple carbon can't be converted to triple cerametallic? or is it possible?-img_1810.jpg
Old Sep 27, 2012 | 10:03 PM
evotris's Avatar
Im confused. Will it work if I just buy the rebuilt kit for triple cerametallic?
Old Sep 27, 2012 | 11:13 PM
94AWDcoupe's Avatar
dont know where you got that but its incorrect.
there are no spring damper discs for the triples. either type.
the carbon discs are 225mm. thats why no one has ever converted a triple or twin carbon to ceramatalic. parts numbers to do it would have been posted right away.
http://www.rhdjapan.com has disc diameters posted
Old Sep 28, 2012 | 02:17 AM
RSMike's Avatar
http://www.exedyusa.com/catalogs/SportsCatalog.pdf
page 48
exedy twin carbon come can come as either sprung centre 225mm, or solid centre 200mm.
exedy triple carbon comes in solid centre, 200mm disc.
It's all in the catalogue, off the Exedy USA website.
Old Sep 28, 2012 | 06:58 AM
94AWDcoupe's Avatar
oops my bad. there seems to be a mistake on rhdjapan site. they dont have a 200mm carbon listed for the twins. both solid center and sprung are listed at 225mm. I thought they did away with the smaller 200mm carbon.
so maybe the 200mm carbon clutches can be converted to ceramic.
Lukelis's Avatar
I checked my carbon disc and there is 200mm
Old Sep 28, 2012 | 06:59 AM
Lukelis's Avatar
YES, of course they can be
FL_SilverEvo8
Nov 22, 2016 06:39 AM
alenewit3928
28
Nov 21, 2014 12:59 AM
konstantinosIX
13
Sep 25, 2011 12:51 PM
crckheadjed
Jun 1, 2011 10:30 AM
evodrivesme
Oct 27, 2010 09:19 AM
