3rd to 4th help
3rd to 4th help
all of a sudden after last night my 3rd to 4th gear shifts do not feel as smooth. It feels like its dosent want to go in smoothly and occasionally will lock me out, im pretty sure its not my driving style although it could be. Maybe its been like this all along who knows. Whats the possible cause, im pretty sure the tranny was rebuilt by a previous owner from research i have dug up. ideas? ps. i dont slam gears or anything. im pretty sure i have a short throw or short shifter also
clutch: ACT 6 puck sprung/10lb flywheel
fluid: Redline MT90
fluid: Redline MT90
all the other gears shift fine though, its not horrible the way 4th is i just feel it could be smoother, and if it were the syncro wouldent it grind? it makes no sounds
My friend drove my car he said it felt fine. I noticed when i shift i wrap my hand around the shifter pulling it towards me a bit. Possibly causing it to get stuck on the shift pattern thing for a split second until i get it in, and when i shift fast in the heat of the moment i dont really realize it
From: Driving ten under in the passing lane, right turn signal on at all times.
My shifter (5 speed) can be notchy, especially when cold or when cornering hard.
For some reason this goes away if I shift with a light a touch as possible.
Any idea why? At any rate, I plan to try new bushings and see if it helps.
EVOREZ1992
Jan 22, 2014 08:15 PM
edIT
Mitsubishi TC-SST Discussion
Oct 8, 2013 06:16 PM
AsILayDying720
Jan 5, 2013 01:39 AM
