E85, should I do it?
Old Oct 3, 2012 | 04:55 AM
Sil'vr-Boi6's Avatar
I'm also in the same boat. I would really love to switch. Are there any hard lines that are more durable and e85 compliant? anybody has a link? Is e85 thicker than 91-93 octane(viscosity)? is there a sensor or a filter that can be used to monitor the quality of gas?
Old Oct 3, 2012 | 05:08 AM
chu's Avatar
chu
Originally Posted by taenaive
Not really practical! I used run on E85 for few months when I lived in LA.you can run 35psi boost and it still fine with E85. 400whp is easy. And if you get close to 500whp you can actually feel that stock chasis and suspension is not really great for this kind of power. It is fun beating any cars on the street. But you need to go to the gas station very often because of horrible gas mileage. and it smells like beer brewing plant from your exhaust and drivers behind you will notice the smell also if you floor it.
However, it is pretty good for passing smoke check.
Agreed. Practicality is the first and most important thing to consider. I ran E-85 for a whole year. I dd and autox my car, and have stations very close by. It was still not practical for me, and I had to plan my routes all the time. If you drive your car a lot, its not practical. The 50hp you gain is not worth the headache imo.
Old Oct 3, 2012 | 06:26 AM
gpfury86's Avatar
Originally Posted by xXANCHORMONXx
I have 1250 Fic blue max injectors
I'm just concerned about bad fuel, what happens if I have a tank of e70 and mash on it? Will my car blow up lol
http://www.quickfueltechnology.com/s...test-tube.html
I ordered that to check e85 levels before I fill up
On a stock turbo/maf car your not going to just mash it and blow it up cause the ethanol content changed 10 points. If that happens your tuner is terrible or there was something that was gonna let loose anyway. It will change the a/f's some when the ethanol content goes down it richens it up a little and vice versa. Just keep an eye on everything, I don't even leave the house without a laptop if I know I'm going to be doing lots of pulls, doesn't ever hurt to do some logging to just keep an eye on everything. I ran the **** outta my stock turbo/ethanol setup at 400 hp and never had an issue. Also I use that test tube to check the ethanol as here in Indiana they have winter blend, make sure it's nice and clean and clear, I always use the same station cause its clean and consistent, I've tested some stations that have milky ethanol and like crap floating in the top. I'm sure those stations would clog injectors much quicker.
Old Oct 3, 2012 | 10:38 AM
xXANCHORMONXx's Avatar
Originally Posted by sparky
Isn't there a station in Redwood City as well?
Yeah that's what I meant San Carlos and redwood city border eachother
Old Oct 3, 2012 | 10:40 AM
What things do I monitor on my logs? And I use a tactrix cable?
Old Oct 3, 2012 | 04:54 PM
siemens03's Avatar
Absolutely, Stock evo 8 motor. evo 9 turbo buschur upper and lowers. Full 3" exhaust 29 psi 399 AWTQ 387 AWHP on e85. I love it except they did not map m cold starts right so in the winter it kinda sucked starting it.
Old Oct 3, 2012 | 05:01 PM
luis!'s Avatar
Just like bud light, always worth it.
Old Oct 3, 2012 | 06:45 PM
Topher86's Avatar
Corn water or bust!
Cleans out the motor and exhaust piping too!
Old Oct 3, 2012 | 06:55 PM
DsmGuy86's Avatar
I'm about to make the switch I wasn't aware they have winter blends ?? In relavence to my tune will I need to be tuned again for winter blend or is it not that big of a difference?
Hey op I am also on the fic 1250 blue max and it's just fine injector for e85
Old Oct 3, 2012 | 07:43 PM
I hope so lol
Just don't smash like crazy but if your tune is conservative it should be fine.
Get that tester I posted
Old Oct 3, 2012 | 08:40 PM
DsmGuy86's Avatar
I hope so lol
Haha already on it Ive never seen one before as soon as I saw you posted it I was on it thanks for the info and foo luck to the op I'm excited about e85 an I only have one station about 20 miles from the house but I'll be stocking up on e85 in the garage
Old Oct 3, 2012 | 08:57 PM
Alpha X's Avatar
Do it! E85 is awesome!
I've been running on E85 for about 3 weeks with zero complaints. I'll probably cycle some pump gas through after the winter
Old Oct 3, 2012 | 09:04 PM
DsmGuy86's Avatar
you get your e85 at ft lewis dont you alpha? thats where ill be getting mine and as far as you guys running pump gas through it are you on a duel map?
EvolutionRacing
Jan 18, 2016 09:55 AM
GinuwineEvo8
Nov 13, 2015 10:27 AM
mrm95
16
Aug 25, 2015 10:26 AM
unowned
Evo X Dyno Results
30
Feb 14, 2013 05:11 PM
MitsuG24
Jul 25, 2011 03:16 PM
