Mivec Delete
Old Oct 2, 2012 | 11:25 PM
Eno-Evo's Avatar
Mivec Delete
Any one have experience with deleting mivec on a evo9 head?
can evo 8 cams be used when this done?
not looking for reasons on why i should keep it.
Old Oct 3, 2012 | 05:26 AM
GTijoejoe's Avatar
Can't you use an Evo8 head?...
... seems silly to delete something that is already applied previously.
Old Oct 3, 2012 | 07:20 AM
blackenedwings's Avatar
Wtf would you delete MIVEC?
Old Oct 3, 2012 | 07:36 AM
Corbin09's Avatar
Swap one of those Hyundai or Kia heads on there! LOL
Old Oct 3, 2012 | 08:16 AM
gpfury86's Avatar
U will need an Evo 8 head and valve cover unless u make a block off plate for where the old mivec sensor was, Its not possible to use an evo 8 intake cam in an evo 9 head. Also u will need to block the oil feed for the mivec on the back of the block.
Old Oct 3, 2012 | 09:07 AM
Ev0ikon's Avatar
Evo8 head if you won't want to work on blocking off oil passage.
Old Oct 3, 2012 | 10:39 AM
reactionevo8's Avatar
http://magnusmotorsports.com/product...ec-eliminator/
that would make it pretty easy to delete mivec...
Old Oct 3, 2012 | 12:04 PM
todd6027's Avatar
why do you want to delete it ?
if you do will you sell the mivec oil control solenoid ?
Old Oct 3, 2012 | 02:34 PM
apagan01's Avatar
Why would one want to delete the mivec. Good power to be had with it.
Old Aug 26, 2013 | 06:26 PM
doghouse's Avatar
My evo 8 head got damage and I purchased an evo 9 head. Is it possible for me to install my evo 8 kelfords in it?
Old Aug 27, 2013 | 11:18 AM
Eno-Evo's Avatar
Yes, you have to remove the mivec cam sensor. I used a 95-96 ecliose cam angle sensor black plug to seal the hole. I ran a oil feed line to the mivec oil port on the head and use a regular cam gear instead of the mivec gear. Reason I decided to convert mines is I got tired of having timing problems with my 2.4l setup so I swap out for adjustable cam gears
Old Aug 27, 2013 | 06:13 PM
doghouse's Avatar
Which series intake cam are you using? Evo 8 or 9?
I want to use my evo 8 cams in the 9 head
Old Aug 27, 2013 | 06:44 PM
boostedadiction's Avatar
why in the world would you want to delete mivec.... im sure someone would swap your mivec stuff for their non mivec stuff though
Old Aug 28, 2013 | 06:05 PM
94AWDcoupe's Avatar
yes 8 cams can be used in 9 head. just have to plug some holes. 9 head is slightly superior even wiithout mivec. it has revised cooling passages, and the long reach plugs for better plug cooling.
Old Aug 28, 2013 | 07:30 PM
doghouse's Avatar
Thanks
