What is the problem?
Old Oct 5, 2012 | 04:32 AM
jameswwt's Avatar
Hi,
im helping a friend to seek for advise as his Evo 9 cylinder 1 seems no pulse and the exhaust sounded like a Scoobie.
Here is what my friend have done :
1) Injectors clean
2) Checked the wires and there's power to the injectors sockets
3) Checked the Ecu harness and no fault found
4) Spark ok
5) Swap a injector ballast but still the same (the ballast is taken from a running Evo)
6) Swap cylinder 1 injector with cylinder 2 injector but still the same
7) During engine on took out injector sockets from 1~4. Only cylinder 1 injector no effect.
What might be the problem? Will a low cylinder compression have such effect?
Thanks
Old Oct 5, 2012 | 06:24 AM
NOMIEZVR4's Avatar
how about the spark plugs? did you check them?
Old Oct 5, 2012 | 07:08 AM
wreckleford's Avatar
Low compression due to damaged valve or piston.
Old Oct 5, 2012 | 07:35 AM
evo8426's Avatar
How low on fuel is the car?
Old Oct 5, 2012 | 09:00 AM
jameswwt's Avatar
I believed this the problem...
Thanks
Old Oct 5, 2012 | 02:52 PM
barneyb's Avatar
A worn loose valve guide can cause this.
Edit: Looking at what I wrote, while true, it doesn't make much sense. A loose valve guide can allow the valve to wobble, not always sealing on it's seat. Eventually the valve will burn.
Old Oct 6, 2012 | 05:19 AM
legacydestroyer's Avatar
Possible bad ground on number one. Do you have a noid light to see if you are getting any pulse at all? Is number one plug wet at all after running for awhile? Does the cylinder look washed? Cylinder leak down test will tell you for sure if you have a more major issue. Good luck.
Old Oct 6, 2012 | 07:42 AM
lostsoulsevo's Avatar
BINGO!!! i'm pretty sure valves are bent for cylinder #1 and/or cracked piston same crap happened to my friend with same symptoms
Old Oct 6, 2012 | 10:43 AM
ExViTermini's Avatar
You can take a long screwdriver and put it against the injector body and put your ear up to it, and you will hear it clicking. If no click, then potential wiring or bad ecu output transistor.
However, more likely case is something wrong internally. Do a compression/leakdown check and get back to us.
Old Oct 6, 2012 | 12:01 PM
jameswwt's Avatar
Hi Guys, its confirmed a damaged piston & ring...
Old Oct 6, 2012 | 12:24 PM
Well that sucks. Time to tear her down and rebuild. Stroker time!!!!! At least you got to the bottom of it fairly quickly and didn't waste alot of time or money on trying to fix something that should get an overhaul to be fixed.
Old Oct 6, 2012 | 06:33 PM
atleast its just a piston ring, change it out and put her back on the street
Old Oct 7, 2012 | 07:20 AM
.:Evil MR:.'s Avatar
i had the same prob with mine so i took the head off and bingo cracked piston on cylinder 1 due to a leaky injector o-ring on cylinder 1.. but the bright side is ,BUILD time!
evoballer
14
Nov 15, 2019 09:42 AM
Enjoi926
May 31, 2017 06:47 PM
khoyer
Dec 6, 2016 10:00 AM
needsboost
25
Jun 28, 2015 02:02 AM
