OK guys i need some help on diagnosing my car
Old Oct 17, 2012 | 03:24 PM
Blojmonster's Avatar
Try unplugging the MAF, then start. If the problem goes aways, then do that cleaning and reset legacydestroyer mentioned. Still there, go buy a new MAF.
Ive had the same issues and After a new set of coils och plugs, i tried that and the problem disappeared...
Old Oct 17, 2012 | 10:52 PM
denver89's Avatar
yeh if my car was doing that i would go straight to the MAF
Old Oct 18, 2012 | 06:39 PM
adamgetem's Avatar
I've tried unplugging the MAF and nothing changed, I've also cleaned it and same result.
Old Oct 19, 2012 | 06:26 PM
adamgetem's Avatar
Bump this issue is really getting on my nerves
Old Oct 19, 2012 | 06:42 PM
bigkert's Avatar
checks
did you actually clean the MAF and the ISC? sticky or bad ISC usually causes this kind of idle! Does it idle the same waywith the A/C turned on? If it does or cuts out, then surely examine the ISC!
Old Oct 19, 2012 | 09:44 PM
adamgetem's Avatar
I cleaned the MAF but not the ISC I'll try that. And yes it runs the same way with the A/C on or off.
04mralliart
Sep 22, 2012 04:12 PM
Ibetchuwontdoit
Lancer Troubleshooting
Oct 12, 2011 08:05 PM
okevolutionVIII
Aug 9, 2009 06:36 PM
wrxedout
Jan 29, 2008 03:06 PM
petey pab
37
Mar 10, 2007 07:52 AM
