Why does the evo idle so rough?
Old Feb 4, 2004 | 07:55 PM
bluevilevo8's Avatar
Any technical reason why the evo idles so rough? Once you get the revs up it's smooth, but that idle is just HORRIBLE. Maybe I should reset my ecu? Some say the grounding kit helps a little. Any thoughts?
Old Feb 4, 2004 | 08:10 PM
Speedlimit's Avatar
Admin Emeritus
I don't believe the idle is bad on most EVO's. You are running your AC all the time in Florida?
Speedlimit...
Old Feb 4, 2004 | 08:47 PM
No. The idle is really bad though. It shakes the damn steering wheel.
Old Feb 4, 2004 | 08:51 PM
Anyway, if this isn't normal, what would cause such a rough idle? (plugs are fine btw)
Old Feb 4, 2004 | 09:08 PM
bcmind's Avatar
I have to agree with you... the idle is rough....
Old Feb 4, 2004 | 09:16 PM
mifesto's Avatar
well then maybe grounding kits will help.. thats wat im thinking
Old Feb 4, 2004 | 10:02 PM
voodooutt's Avatar
lol, i was used to a smmmooooth v-6 and hopped into the EVO and I was like WTF is this crap - rough - shakes.. lol... its a 4-banger!
Old Feb 4, 2004 | 10:08 PM
Beevo's Avatar
evos are practically street legal race cars. rough idle might be due to aggressive cam design or solid motor mounts.
Old Feb 4, 2004 | 10:10 PM
helli0n's Avatar
Check you engine temp when you stop...see if you can touch the engine or turn on your heat. If its not almost immediately very very hot then either you have not let the car warm up properly or the thermostat could be stuck open. I just recently started having the rough idle and noticed that even after let my engine warm up for 10mins and drove for another 20mins. When I stopped it was idling rough & I was able to put my hand on the engine...it was only warm and not hot like it should have been. I talked to a mechanic friend & he said that the thermostat might be stuck open. I am going to replace my stock thermostat with a Ralliart one now...
Old Feb 4, 2004 | 10:13 PM
raywong's Avatar
Mine's rough too, comparing to my 328i.
Old Feb 4, 2004 | 10:22 PM
mifesto's Avatar
thermo? hmmm maybe you didnt cool the car down properly
Old Feb 4, 2004 | 10:54 PM
SinCityEvo's Avatar
Man, it's a race car. Get used to it
Old Feb 5, 2004 | 01:03 AM
3K's Avatar
3K
I agree DO NOT drive around in stop and go traffic with the A/C on.
Old Feb 5, 2004 | 05:50 AM
If you "just recently" started having the rough idle, it's the plugs. Trust me.
Old Feb 5, 2004 | 06:13 AM
ShapeGSX's Avatar
Why?
