Car Runs Too Cold
Old Oct 12, 2012 | 02:25 PM
  #31
heel2toe's Avatar
Here's a couple photos. Are you looking for anything in particular?
Old Oct 12, 2012 | 02:36 PM
  #32
todd6027's Avatar
just by chance is it identical to your original one
Old Oct 12, 2012 | 03:06 PM
  #33
heel2toe's Avatar
I seemed to have misplaced my original thermostat so those pictures are of the one I just took out. I will be picking up my new replacement in the morning from the dealership and I imagine it will look identical to the one I pulled out. This will be my third thermostat and all of them are OEM parts for the record.
Old Oct 12, 2012 | 06:29 PM
  #34
humbled8's Avatar
t-stat stuck
Old Oct 12, 2012 | 09:13 PM
  #35
makulitz's Avatar
Originally Posted by heel2toe
Halfway open is interesting, that could definitely be it. I figured it was either open or closed.
Is this the thing you are referring to? If so I believe I put that in the front.
yup.. that's the one im talking about.. it should be in the top and the spring should be facing inside the housing.
i replaced mine with crossed reference part number only and had a hard time as my car is an evo IV from japan. i just bought it off from my local parts store only. but then again, fixed my issue completely. did u get to bleed your rad properly?
Old Oct 13, 2012 | 06:41 AM
  #36
heel2toe's Avatar
Thanks for the reply. Ill be picking up the new thermostat today and putting it in with the bleeder thingy positioned at the top aka 12 o'clock position.
The radiator has always been bled properly (front end in the air, radiator cap off, heat on , let the fan to turn on to cycle it through the heater core, top off) but Im sick of making a mess so im stopping at the parts store today as well to pick up a spill free funnel to make my life easier.
Hopefully the new thermostat fixes things. Im still a little skeptical because when this first happened the new thermostat didnt fix it, but maybe that one had a defect. I brought this up to the parts guy at Mitsubishi but he said unfortunately the parts arent warrantied unless they were installed by a professional.
Old Oct 13, 2012 | 09:03 PM
  #37
makulitz's Avatar
alright.. just give us a shout if it fix the problem.
Old Oct 17, 2012 | 08:10 AM
  #38
heel2toe's Avatar
I apologize for the delayed feedback. I havent tested the car cruising on the highway yet but so far I think the new thermostat has fixed it. The car seems to come up to temp much quicker than before. I am taking the car to New York on Friday so I will report back then as thatll be the true test.
In the meantime, thanks everyone for all of your help! The thermostat was the only thing in my mind that made sense but I didnt give it a second thought because I assumed the replacement part was fine.
Old Oct 17, 2012 | 09:21 PM
  #39
makulitz's Avatar
good for you mate.. i hope that fixed your problem.
Old Oct 19, 2012 | 06:29 AM
  #40
heel2toe's Avatar
you guys rock, highway temps are back to where they should be!! thanks for convincing me to get another thermostat!!
Old Oct 19, 2012 | 01:05 PM
  #41
makulitz's Avatar
Let's drink to that bud! Haha! Cheers!
Old Oct 20, 2012 | 11:58 AM
  #42
todd6027's Avatar
sorted
Old Oct 20, 2012 | 12:43 PM
  #43
AWDBus's Avatar
I ran into the same thing, it took 3 to get a good one.
Old Oct 22, 2012 | 08:43 AM
  #44
E85R32's Avatar
One other thing to consider is that running on E-85 you almost have to run a very agressive ignition map to get it to stay warm. I had a high compression honda that I had to run more ignition and pull fuel to get it to stay warm. Just food for thought.
Old Oct 22, 2012 | 10:18 AM
  #45
heel2toe's Avatar
Interesting...I wasnt sure what effect the E85 had on my temps. I know an alcohol based fuel will obviously cools things off but I wasnt sure if that was why my temps were so low.
The new thermostat got things back to where they should be so the car is fixed. I'm glad you mentioned that though because it definitely crossed my mind when I started this thread hence why I mentioned it was running on E85 in the first post.
heel2toe
164
Feb 13, 2018 01:03 AM
MaD_CaNaBiCe
13
Feb 6, 2016 06:11 AM
L888Apex
Nov 1, 2012 01:27 PM
MaD_CaNaBiCe
Jul 9, 2011 08:56 AM
Adam@MMS
Jun 1, 2010 11:44 PM
