HKS 272 cams?
Old Oct 14, 2012 | 11:28 PM
akqowns's Avatar
HKS 272 cams?
Previous owner told me that the car has HKS 272 cams(both) installed.
since I have to take the cover off to check, I didn't bother to check .
The thing is my idle isn't rough at all. All 272 seemed idle rough , but mine doesn't at all, just like normal idle.
Is there anything wrong? or should I change something else to make the idle sound rough?
Old Oct 15, 2012 | 05:58 AM
PatricksEvilEvo's Avatar
HKS cams are very mild AND with a good tune you really wont even notice you have them at idle.
Old Oct 15, 2012 | 07:04 AM
heel2toe's Avatar
^ correct depending on your tuner, your idle can be made quite smooth. my car has a set of hks 272's and used to have a little lope but now the idle is really smooth and you can barely notice the difference in the cams at idle
Old Oct 15, 2012 | 07:36 AM
Ev0ikon's Avatar
This is the main reason I love those cams! They also make wicked TQ on low RPM.
I hate wobbly/stuttering idling. :}
Old Oct 15, 2012 | 12:20 PM
akqowns's Avatar
Oh.......... I kinda like rough idle, yea it has been tuned after the install.
is it bad having a rough idle? if not, how can I have it ?
Old Oct 15, 2012 | 01:00 PM
Ev0ikon's Avatar
Bring it to your tuner then. It's easy to make it idle like crap. Guess I will never understand things people want.
Old Oct 15, 2012 | 06:40 PM
AreSTG's Avatar
swap out to 280's. you'll love the idle if that's all you're looking for. Or maybe pull your MAF sensor plug
Old Oct 16, 2012 | 04:21 AM
thegrownsamonie's Avatar
I have HKS 272 cams my idle is slightly rough. The air fuel ratio fluctuates at idle but pulls clean. I don't know where to tune it!
Old Oct 16, 2012 | 06:47 AM
Travis@GSC's Avatar
You dont want a rough idle, you want lope...there is a difference. With MIVEC cars, its just a tune thing.
Old Oct 16, 2012 | 06:50 AM
wazzelby's Avatar
If it's a IX then just lower your timing a little at the idle cells when you're tuning. Maybe drop your idle under 800 RPM if it's higher than that.
Old Oct 16, 2012 | 08:48 AM
EvocentriK's Avatar
If it has cam gears and they've been adjusted to reduce overlap that could also cause them to idle smooth. Installed 0,0 they should lope a little if they are HKS 272's and the tuner hasn't used the MIVEC to reduce lope.
Old Oct 16, 2012 | 10:18 AM
dastallion951's Avatar
it could either be tuned right and minimum cam lope, an easy way to determine if you have hks cams on it,they cast stamped there hks logo on both of the cams.....if i remember where they are right since i havent seen mine in a year or two, they should be on the side of the cams by the cam angle sensor. good luck hopefully he put them in.
Old Oct 16, 2012 | 07:41 PM
akqowns's Avatar
This is 05 Evo 8, so it's not a MIVEC head, and no aftermarket cam gears.
Yes ,not rough..want lope idle, just like gr gr gr gr gr ~
Is there anyway I can check if it my car has cams without open the valve cover?
Old Oct 17, 2012 | 07:23 AM
Ev0ikon's Avatar
Not really... Unless you have X-ray vision.
Old Oct 17, 2012 | 08:36 AM
akqowns's Avatar
hm.. so if I lower the idle, and the car makes lope sound, does that mean it has cams?
or stock cams could make lope sound as well?
