Issue I have never seen...
Other issues
I'll spend Saturday tightening down and checking everything in the car. this can't be the reason why it falls on its face when I get on it on 3rd gear, shift at 7K into 4th gear and the car just sputters for about 30seconds. The sputtering is similar to when a hose pops off.
Big Changes
Freddie,
I put in a brand new:
Thermostat
Camshaft Position Sensor
Coolant Temperature Sensor
Coolant Temperature Gauge Unit
I checked for loose clamps, hoses, ground wires, power wires, connectors, cut wires, etc. and I didn't find anything significant.
I was able to run her from a slight roll (<5mph) 1st thru 3rd gear @ 8K RPM, no issues - that the top of 4th gear, hit redline and she had a slight misfire (more of a hesitation/sag) for about 10 seconds and then it went away (when it started I just let off the throttle and let her coast).
Ran 1st thru 3rd again, strong as hell, no issues. -- I think I bumped my boost controller a couple of times while replacing my sensors and thermostat because during the run, boost was 31-32psi (solid, no fluctuations).
I just did those two runs to take it easy on her (plus the cops were out), she runs pretty rich (would like to lean her out a bit but keeping it safe/conservative). When can I get on your schedule?
I also added the AEM Digital Water Temp Gauge and AEM Digital Volt Meter. The Volt Meter bounces around quite a bit (11-ish to 14-ish while running). Is there someone out there who can tell if that is normal?
The only sensor I haven't replaced that I'm considering changing is the Camshaft Position Sensor. I'll run her again tomorrow at 30psi to see how she does and let you know.
Thermostat
i am having the same type of problem but mine starts doing it coasting from a stop but my car is on aem all my mods are in my sig if anyone could help me out i would appreciate it a lot. car missing and sputters and popping coming to a stop if i cycle the ecu power. the car starts driving fine. could my aem be my problem. what else could i look for this cam sensor is brand new like june new and maybe 2k miles. because this is a new motor that is in my car now.... thanks guys i hope you guys figure your problem out.
After the car is started, voltage should never get below 13v or so. You have an electrical problem, either a ground, battery, alternator or something else. I wouldnt bother replacing any more sensors, that doesnt sound like the problem. Do you have a digital volt/ohm meter to check some things?
Freddie,
Thermostat
Thermostat
Tony, you will have to sort out the electrical gremlins before I can tune it again, or we will be chasing out tails again... good luck brother, I have been busy as I am moving to VA in a few weeks...
Misfire Gone!
Freddie,
Mike's recommendation to replace my valve springs turned out to be the fix for my misfire issues. I ran her straight through 2-3-4 gears, slamming the rev limiter in each gear and not a single misfire or hickup. I kept an eye on the AFR's (I haven't pulled a data log yet) and she ran a little on the rich side but it was strong.
I had all new valves, springs, guides, and seals done.
Thanks for your help through all this...Mike, You Da Man!
Tony
Tony
Freddie,
Tony
Tony
Teal2nnr
Feb 25, 2017 10:55 PM
ziad
Jun 12, 2012 08:22 PM
