600WHP Goal help
Old Oct 30, 2012 | 09:53 AM
masonh's Avatar
you can buy the cams cheaper than the 2150's, and like JB said above on pump gas you don't need huge injectors.i had the Ptrim T67 on my old motor and made 600 on pump,but that turbo spools slow.30psi at 5250rpm and then i had to shift early because the AMS 2.3L was only recommended to 7800rpm.
Old Oct 30, 2012 | 10:13 AM
STIKiller4G63's Avatar
What injectors did you run with ur ptrim?
Old Oct 30, 2012 | 10:26 AM
Robertv34's Avatar
Yes just like everyone is saying dont look for bigger injectors if your wanting 600 on PUMP even that double pumper is a bit much.....What you could do is use that 700 dollars you wanted to spend on 2150's towards better cams.....hell you could even sell your double pumper for a sinlge and make cash of that too...
Old Oct 31, 2012 | 06:07 AM
Good to know man. Thanks for the advice! I'll have to poke around for some cams if I want to make some serious power
Old Oct 31, 2012 | 01:03 PM
masonh's Avatar
i was running the 2150's but i was going to run E85 most of the time.my car also runs on the AEM EMS .
RacerX-Ralliart
195
Mar 15, 2021 04:16 PM
Rpf1evolution
14
Sep 27, 2013 09:21 AM
spadednick88
Aug 13, 2012 10:15 AM
chaosfiend21
Aug 6, 2012 02:28 AM
3gEclipseTurbo
68
Jun 27, 2010 06:33 AM
