Screetching from Front Drivers side tire.
Old Nov 4, 2012 | 01:12 PM
Randal's Avatar
Guest
So I replaced my Clutch this morning and after I finished I took it for a test drive. The drivers side from wheel screetchs from 20 to 40mph then From 40 all the way to 0mph it screetchs very loud. It has nothing to do with brakes because it does not change when brakes are applied. What can be the Culprit? Wheel bearings?
Old Nov 4, 2012 | 06:43 PM
lostsoulsevo's Avatar
did you put the input shaft in all the way?
Old Nov 4, 2012 | 07:46 PM
Randal's Avatar
Guest
Yes... Now I bent out a little bit the dust shield since it could of been rubbing the inside of the disk hence the screetching. I will drive it tommorow. I also noticed today the noise goes away when I steer to the right. The noise only happens while you are driving and not while stopped
Old Nov 4, 2012 | 08:07 PM
yea most likely the dust shield for the brakes
Old Nov 5, 2012 | 06:20 AM
Randal's Avatar
Guest
That's exactly what it was. Not doing it anymore as of now.
pkevoIXMR
Sep 2, 2020 07:11 PM
IX_MR
Feb 21, 2020 08:46 PM
Turborico
Feb 8, 2014 12:42 PM
KenyonKanye
Jul 19, 2013 06:45 PM
GiLizILL
Mar 19, 2013 07:29 PM
