deleting fan module for radiator?
Old Nov 16, 2012 | 10:52 AM
bnr34rb26dett's Avatar
I was wondering how you could go about removing the radiator fan control module.
There are three cables going into the module and two coming out into the fan. What's the best way to bypass this module?
Thanks.
Old Nov 16, 2012 | 12:44 PM
whiteEvo08Y's Avatar
Why are you removing the fan control module?
Old Nov 16, 2012 | 01:17 PM
Because it will look prettier without one. And I have seen them removed.
I don't have ac fan since ac has been removed. So it's just one fan that needs to be plugged in
Old Nov 16, 2012 | 01:31 PM
I have the same setup as you. No ac or ac fan. but i still keep it for my f-a-l Fan setup so it can turn on Using the Stock Water Temp Sensor . How are you going to setup your fan if you remove the module( Planning to put a switch to turn on the fan Manuel or What?
Old Nov 16, 2012 | 03:08 PM
im not sure. thats the question im asking. lol.
I saw fan module deleted evos so i was wondering...
Old Nov 16, 2012 | 03:17 PM
wizzo 8's Avatar
If you do this the fan will stay on at full speed at all times the key is in the on position. It will even stay on for about 15 sec after you turn the key off.
Old Nov 16, 2012 | 04:55 PM
thanks for the response.
i guess thats just how people are running their cars then. full blast fan at all times....
Old Nov 16, 2012 | 05:02 PM
EvoFredo's Avatar
you can always control the fan by wiring it to a switch . just buy a fan relay kit and manually turn on the fan. good luck .
Old Nov 16, 2012 | 05:45 PM
wreckleford's Avatar
You can use the point that controls the a/c fan to control the radiator fan also. Thats what everyone does when swapping an 8 ECU into earlier Evos.
Old Nov 16, 2012 | 05:46 PM
fouringEVO's Avatar
If u want the look of no module just relocate it out of the way so it isnt seen then just run the 2 wires to the fan itself from the module
Old Nov 16, 2012 | 05:50 PM
ak47po's Avatar
Stupid idea.
stunt2
May 9, 2015 08:59 PM
GGIXMRSE06
May 5, 2015 03:49 AM
88888
Jun 13, 2013 08:40 PM
chrisff521
Aug 29, 2011 07:41 AM
miller121mx
May 20, 2010 09:42 PM
