what can cause rad fan to run constantly ?
Old May 5, 2015 | 10:24 PM
stunt2's Avatar
Question what can cause rad fan to run constantly ?
hey guys
what can cause radiator fan to run constantly, as soon as I start the car, even on cold engine ?
note that I have evo4 and it doesn't have PWM module as later evos, just the fan itself
so, what malfunction can trigger the fans ?
Old May 5, 2015 | 10:34 PM
LetsGetThisDone's Avatar
Bad coolant temp sensor, or stuck relay.
Old May 7, 2015 | 07:04 AM
peisden's Avatar
Your fan control unit is bad. When these go the fans stay on constantly
Old May 7, 2015 | 11:00 AM
stunt2's Avatar
which unit ?
I have no unit that controls fans
p.s. tried several different water temp sensors but still the same
Old May 7, 2015 | 11:01 AM
stunt2's Avatar
which unit ?
Old May 7, 2015 | 11:24 AM
The fan is still controlled by the ECU, or a temperature switch, you have a bad coolant temp sensor or temperature switch, or a stuck relay..
Old May 7, 2015 | 12:52 PM
Ev0ikon's Avatar
Maybe it was bypassed and wired directly by previous owner.
When I had a problem with by DSM fan controller I wired it up directly on the key start and fan will run anytime the key is on run.
Old May 8, 2015 | 07:46 AM
stunt2's Avatar
yes, the fan is controlled by ecu and coolant temp switch, which I've swapped out three different ones to rule out this issue...
nothing was bypassed worked as it should work, during the years I own this car
haven't checked for stuck relay though..
Old May 9, 2015 | 08:59 PM
sourcelx's Avatar
The fan controller is a little black box that sits on the fan shroud. I had a lancer have that issue. As soon as you put the key on the fan would turn on. I would smack the box and it would drop in rpms and bounce around. Otherwise, have you checked for maybe a stuck relay?
Chrushev
Lancer Troubleshooting
13
Dec 7, 2016 09:08 PM
Ricekiller81
11
Sep 9, 2013 10:52 AM
patrickhvr
Jun 25, 2013 09:56 PM
Racman709394
Dec 13, 2012 04:12 AM
sktng22
Oct 26, 2011 02:23 PM
