Honda radiator need help finding units
Old Nov 16, 2012 | 01:49 PM
Boostfarmer's Avatar
Ok so my evo radiator blew up on a dyno. So I need to get a new one and looking at going with the Honda dual core ones I saw on here. What I need is the ones people are running with no problems. Current power is 385/402 wheel numbers. So I am asking who's running them with these number that don't over heat so I know which ones to get.
Also how easy is the install thanks guys just don't have time to read since my cars down and I'm at work..... Any help would be great
Old Nov 16, 2012 | 09:54 PM
76 views no posts I need help guys just need to know what to get.....
Old Nov 17, 2012 | 12:15 AM
evilempire76's Avatar
Read this:
https://www.evolutionm.net/forums/ev...-radiator.html
I would still recommend a stock Evo radiator over the half size honda radiators.
Old Nov 17, 2012 | 11:29 AM
cmspaz's Avatar
With those kind of numbers you're still on stock turbo, no reason to run a half unless you need the clearance to go with a WAY bigger snail or front-facing setup. The latter is straight retarded on a street car and the former is probably not something you're considering for a while at your current numbers.
In the end, it's likely not worth it for you.
Old Nov 17, 2012 | 12:36 PM
AreSTG's Avatar
i'm curious if you fixed the cause of the radiator blowing up? did your headgasket go?
Old Nov 17, 2012 | 04:20 PM
sktng22's Avatar
if your car is a daily driver i would recommend staying with a full size rad over a half. mishimoto makes a pretty good full size rad for a decent price
Old Nov 17, 2012 | 09:49 PM
It wasnt the head gasket thats fine no oil and everything fine. My tuner changed the water pump so only thing I can think is air was in the system.... But he forgot it was on a evo 9 turbo so I am a little perplexed as to why that would cause the radiator to go? He has the data log to show when it blew its highest coolant temp was 188? So I'm drawing a blank. If it happens again I will hold him accountable but as of now I'm writing it off as a fluke... Hopefully a new radiator fixes it and I can wash my hands of the bad event....
Viegasjuice
Jul 15, 2019 12:09 AM
TheBigD
11
Mar 7, 2014 07:08 AM
pflores210
13
Feb 10, 2011 07:40 AM
LetsGo82nd
Jul 26, 2009 06:41 PM
Batmann!
May 3, 2006 08:26 PM
